tricks to getting undercoating off quick & cheap? #1284250
08/12/12 09:31 PM
08/12/12 09:31 PM
Fitchburg,Massachusetts
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
Most of it is dry and brittle but it still takes some effort to scrape off.
Snap-On tool guy wants to sell me a $500 Crud thug.
Chemicals are expensive also plus messy and hazardous to my health.
Any other suggestions to help save my sanity and arms from scraping?
Re: tricks to getting undercoating off quick & cheap? [Re: MPerry] #1284251
08/12/12 09:48 PM
08/12/12 09:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Got a decent compressor? Get this...
http://www.harborfreight.com/compact-air-needle-scaler-96997.html
And ear plugs...
It won't take everything off but most of it... Whats left use a propane torch & a putty knife & finally solvent & a rag...
Re: tricks to getting undercoating off quick & cheap? [Re: 1_WILD_RT] #1284252
08/12/12 09:58 PM
08/12/12 09:58 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Rent a steam cleaner. I've tried every method there is, it's BY FAR the easiest and fastest! 200+ degree water, high presure washer = clean to bare metal (including some paint!). It's a wet messy job but it's eco friendly and suprisingly easy to clean up.
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284253
08/12/12 09:59 PM
08/12/12 09:59 PM
New Kent, Virginia
matts69Dart Offline
matts69Dart  Offline
New Kent, Virginia
Heat gun and scraper....comes off like butter.
Re: tricks to getting undercoating off quick & cheap? [Re: matts69Dart] #1284254
08/12/12 10:05 PM
08/12/12 10:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Before
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284255
08/12/12 10:07 PM
08/12/12 10:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3 hours later
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284256
08/12/12 10:08 PM
08/12/12 10:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Closer
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284257
08/12/12 10:09 PM
08/12/12 10:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After 2
What remains is the factory dip sealer, primer, and paint overspray along with a bit of surface rust. Side benifit is that you can get a good pattern for your under carriage over spray and dip coat if you are going for a factory appearance. Sand blasting, scraping, and other forms of stripping will remove the factory finishes as well as the undercoating.
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284258
08/12/12 10:14 PM
08/12/12 10:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After a hose off and a sweep here's all that was left.
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284259
08/12/12 10:23 PM
08/12/12 10:23 PM
MPerry Offline OP
Mopahts memba'
MPerry  Offline OP
Mopahts memba'
Thats cool! Just wish I was set up where I could use a steam cleaner on the car.
Factory appearance isn't important on this one. Its a 74 Satellite currently getting springs moved inboard. I have the car stuck in the garage on stands leveled marked for the install.
Going to snag the heat gun from the shop and give it a whirl to see if its any easier.
If not I'll hit harbor freight up for the needle scaler to give it a shot. I'm just concerned with the stories I've heard about their tools failing often. That one is cheap enough though where it won't hurt too bad if it does.
Re: tricks to getting undercoating off quick & cheap? [Re: MPerry] #1284260
08/12/12 10:25 PM
08/12/12 10:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd use the heat gun and a scraper then, WEAR COVERALLS because you WILL be wearing some hot tar along the way! The needle scalers work but they will also chew up the surface of the sheet metal, sometimes pretty badly.....
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284261
08/12/12 10:28 PM
08/12/12 10:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I second this suggestion, by far the BEST way.
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284262
08/12/12 10:39 PM
08/12/12 10:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
they only chew up the surface of the sheet metal if your keep hammering away at areas that aren't brittle.... The needle scaler with cause lots of the undercoating to crumble but if it's still rubbery it will move around instead of falling off.... If it doesn't fall off easily you don't keep hammering at it, you move along knowing the next step will take care of those areas....
If you keep hammering away at it yes you will scar the sheet metal...
Steam cleaner is great if you have an area to use it....
Re: tricks to getting undercoating off quick & cheap? [Re: ScottSmith_Harms] #1284263
08/12/12 11:58 PM
08/12/12 11:58 PM
Star Idaho
67vertman Online rolleyes
67vertman  Online Rolleyes
Star Idaho
That is how I did mine. Melted the under coating like butter.
Re: tricks to getting undercoating off quick & cheap? [Re: 67vertman] #1284264
08/13/12 12:22 PM
08/13/12 12:22 PM
dogdays Offline
dogdays  Offline
A friend bought a HF needle scaler, it lasted one hour. He returned it, got another one and put it on the shelf for the next time.
Sub-cool the area with dry ice and it gets so brittle it'll pop off, advice from this board a couple of years ago.
R.
Re: tricks to getting undercoating off quick & cheap? [Re: MPerry] #1284265
08/14/12 10:34 AM
08/14/12 10:34 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Did my undercarriage with a simple Bernzomatic and a putty knife.
It literally came off in sheets.
Re: tricks to getting undercoating off quick & cheap? [Re: Commando1] #1284266
08/14/12 12:41 PM
08/14/12 12:41 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
I did this too. Propane torch and putty scraper. Since you are on jack stands, and you did say cheap. It will take some time and stink up the garage. Get a fan going, use gloves...Remove things on the other side of the metal.
