unknown wires in dash harness #1283891
08/12/12 08:25 AM
08/12/12 08:25 AM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Im putting the dash back together in my 70 RR and have come across two connections which I didnt label or the labels fell off. Anyway is there anyone who can offer up what they may be? Is it possible they dont connect to anything?
Re: unknown wires in dash harness [Re: LimeliteAero] #1283892
08/12/12 10:00 AM
08/12/12 10:00 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Do you have light group? They won't connect to anything if the car doesn't have the option they would connect to.
Re: unknown wires in dash harness [Re: JohnRR] #1283893
08/12/12 04:48 PM
08/12/12 04:48 PM
SE Pa.
SE Pa.
I dont have a map light, Im not sure what is included in the light group.
Thanks John!
Re: unknown wires in dash harness [Re: LimeliteAero] #1283894
08/12/12 06:13 PM
08/12/12 06:13 PM
Map light , glove box light , trunk light , light on the column to shine on the ignition lock , ashtray light , fender mounted turn signals ... to name a few ...
Re: unknown wires in dash harness [Re: LimeliteAero] #1283895
08/12/12 07:08 PM
08/12/12 07:08 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks John!
isn't that the plug for the optional key light? pretty sure the timer plugs into it.
Re: unknown wires in dash harness [Re: mikemee1331] #1283896
08/13/12 12:24 AM
08/13/12 12:24 AM
W
wate Offline
wate  Offline
W
yellow/red plug is the power for your radio
Re: unknown wires in dash harness [Re: LimeliteAero] #1283897
08/13/12 12:33 AM
08/13/12 12:33 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A comment you may find useful... The work done looks great, but anything that should ground by being bolted to the dash frame may give you problems as the paint is heavy enough that it may insulate/isolate components...
Re: unknown wires in dash harness [Re: 1_WILD_RT] #1283898
08/13/12 09:11 AM
08/13/12 09:11 AM
SE Pa.
SE Pa.
Thanks Randy...I have it covered with previous experience.
Wate...are you 100% certain? I have the radio labeled as the Orange and White wired connection not the Yellow and Red.
Re: unknown wires in dash harness [Re: LimeliteAero] #1283899
08/13/12 09:40 AM
08/13/12 09:40 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think the red and yellow/black T shaped plug is part of the light pkg for the key on light dimmer relay
I would have to ck a 70 book to ck on the yellow with black tracer wire bullit plug
T-shaped radio plug has an orange(lamp circuit) and a red (Battery circuit) wires
Re: unknown wires in dash harness [Re: gtx6970] #1283900
08/13/12 11:52 AM
08/13/12 11:52 AM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
Pretty sure the red and yellow/black T shaped plug is part of the light pkg - it has a terminator with a diode inline, it makes the key buzzer go off when you leave the lights on.
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: unknown wires in dash harness [Re: LimeliteAero] #1283901
08/13/12 02:02 PM
08/13/12 02:02 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
per '70 Plymouth Service Manual:
Instrument Panel Wiring Diagram - Belvedere
Ignition Switch Lamp Ground:
M6A-18Y* & M6B-18Y* (18ga. yellow w/tracer)
Headlight Warning Buzzer:
L6-18Y* & L6A-18Y* (18ga. yellow w/tracer)
Q13A-18R & Q13B-18R (18ga. red)
Re: unknown wires in dash harness [Re: 6bblgt] #1283902
08/13/12 02:39 PM
08/13/12 02:39 PM
SE Pa.
SE Pa.
Thanks Dan!
Ive been looking at the FSM today to try and figure the dash out.
right now I have the wiring to it but no idea how to mount the heater control lamp????
Re: unknown wires in dash harness [Re: LimeliteAero] #1283903
08/13/12 03:43 PM
08/13/12 03:43 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Thanks Dan!
Here is a photo!!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: unknown wires in dash harness [Re: 70gtx440dana] #1283904
08/13/12 03:44 PM
08/13/12 03:44 PM
Lansing, MI
Lansing, MI
Another!!!
Re: unknown wires in dash harness [Re: 70gtx440dana] #1283905
08/13/12 03:46 PM
08/13/12 03:46 PM
Lansing, MI
Lansing, MI
Heater control only!
Re: unknown wires in dash harness [Re: 70gtx440dana] #1283906
08/13/12 06:35 PM
08/13/12 06:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the heater lights should end in a bullet connector which plugs into a 3 outlet female bullet receptacle along with the ashtray light. this is tied to the dashboard dimmer control. that's how my 69 RR is. don't think that changed for 1970.
Re: unknown wires in dash harness [Re: 70gtx440dana] #1283907
08/14/12 09:05 AM
08/14/12 09:05 AM
SE Pa.
SE Pa.
Another!!!
Thanks Joe!!! Exactly what I needed! Now I need another day with a few hours to kill and the dash is a wrap.
Moparts needs a "like" button!
