440 marine block #1283219
08/10/12 07:57 PM
08/10/12 07:57 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
are they any stronger than a older block?
anyone have one apart at all? are the mains thicker
like some of the 6630-440 late blocks.
i got dibs on one for 500 bucks
Re: 440 marine block [Re: dmking] #1283220
08/10/12 10:50 PM
08/10/12 10:50 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
no different than a std. 440 block so don't let the seller FOOL you , but I would ask the type of cooling system it had , heat exchanger or RAW WATER , if raw water and it's been in SALT WATER ...
RUN FOREST RUN
Re: 440 marine block [Re: JohnRR] #1283221
08/10/12 11:29 PM
08/10/12 11:29 PM
IN
ahy Offline
ahy  Offline
IN
I don't know the current going rate... but $500 sounds like a lot for a 440 block.
Re: 440 marine block [Re: ahy] #1283222
08/10/12 11:40 PM
08/10/12 11:40 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
it is a running long block. i said 500 for me may not be a good thing cause i split a stock 73 block and will end up throwing everything away but the block and caps. i got the sholder shrug so this will not be for me. just wondering if there is any strength differences. it is a forged crank though.
Re: 440 marine block [Re: dmking] #1283223
08/11/12 01:00 AM
08/11/12 01:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All the ones I've seen were just production blocks...
different boat companies use to buy a quantity at
a time from what ever auto company would sell them
the cheapest price.... and some would change brands
during the season build... my boat(Searay) has a ford
but most were chevy
Re: 440 marine block [Re: dmking] #1283224
08/12/12 11:57 AM
08/12/12 11:57 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I know you're after the block but if it is RH rotation the crank knurling at the rear seal is not gonna work for you.
Re: 440 marine block [Re: Dean_Kuzluzski] #1283225
08/12/12 12:26 PM
08/12/12 12:26 PM
jonestown,pa
dmking Offline OP
dmking  Offline OP
jonestown,pa
yeah that would be funny not catching that and have it pump oil out>
looking at a 73 400 block to step on.
Re: 440 marine block [Re: dmking] #1283226
08/13/12 09:43 AM
08/13/12 09:43 AM
JohnRR Offline
JohnRR  Offline
If you split a stock block it's probably time to just pony up for a REAL block and be done wit hit . Contact Keoleno for a good lock deck block.
