Re: Break in oil
[Re: terzmo]
#1282040
08/09/12 06:25 PM
08/09/12 06:25 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Personally I wouldnt use a syn blend oil on breakin.
Alot of guys do it without issues, but....
Id use Rotella and a bottle of Comp Cams or similar additive.
I go a little over board with my cam break ins. A local machine shop has oil that they had a local refinery formulate for them. It is chock full of zinc. I use their oil, and 2 bottles of SLOB.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Break in oil
[Re: terzmo]
#1282042
08/09/12 06:29 PM
08/09/12 06:29 PM
moparpollack
Lil Herman
Lil Herman
85086
Any oil with ZPPD there are only four. Joe Gibbs or Valvoline are the most common.
Re: Break in oil
[Re: terzmo]
#1282043
08/09/12 06:32 PM
08/09/12 06:32 PM
RapidRobert
synthetic is a no no for breakin unless the fact that it is a diesel syn and or a part syn blend makes it OK to use for breakin but I'd be doubtful but I'm not an oil guy & am going by what I know so far. I'd drain it & go with a proven performer like Bradd Penn & other proven brands. You've went to far to take a risk now & after it's broken in & running strong you will have forgotten about the little bit of extra time/money it took to rectify this
Re: Break in oil
[Re: RapidRobert]
#1282046
08/09/12 07:59 PM
08/09/12 07:59 PM
Von
NE Oklahoma
Bradd Penn
Cept Penn is a semisyn...
I called Total Seal and they told me no syn or semisyn for at least 800 miles..so
Plenty of race motors come out of the box with Penn.
I was talking to a local machinist the other day he uses Mobil full syn on the skirts, rings when putting motors together..
So, flip, IDK. Id still play it safe and go with a full dino oil...
Re: Break in oil
[Re: mikemee1331]
#1282047
08/09/12 08:03 PM
08/09/12 08:03 PM
Von
NE Oklahoma
it's my understanding that diesel oils have the right amount of zinc in them. since i don't know that to be 100% true with a synthetic blend oil i would just get 2 bottles of Lucas breakin additive and one to the break in oil and the other after you change it. most auto parts stores have Lucas.
As far as the diesel oil, they or may not have enough zinc...If you have moderate to high spring pressure, probably not. Id still add a bottle of Comp, EOS, etc.
I know nothing about the Lucas break in oil. Id like to see a lab report on it. If its like the rest of the Lucas stuff...run...
EDIT. Found some info on the Lucas break in oil, looks to be good stuff.
Re: Break in oil
[Re: Von]
#1282049
08/09/12 09:13 PM
08/09/12 09:13 PM
moparpollack
Lil Herman
Lil Herman
85086
No zinc in any of the deisel oils since they put the cats on them since the zinc plugs them up.
Re: Break in oil
[Re: moparpollack]
#1282051
08/10/12 10:23 AM
08/10/12 10:23 AM
Von
NE Oklahoma
[quote
What is your definition of "No zinc"
I just looked at some recent VOAs, DelVac, Rotella, Napa 15-40 all show over 1200ppm of Zinc. Not what I would call "No zinc"
The stuff doesnt have 1600 or so like it did 5 years ago, but considerably better than a SL-SN oil...
Re: Break in oil
[Re: Von]
#1282052
08/10/12 10:28 AM
08/10/12 10:28 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
[quote
You want Zinc!!
Re: Break in oil
[Re: elmor]
#1282053
08/10/12 11:34 AM
08/10/12 11:34 AM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
But since you now know that oil needs zinc (zddp)for flat-tappet cams, especially during the initial break-in, keep in mind you can have too much in the oil too...so don't go overboard adding excess oil supplements to get the zinc levels up there. Too much zinc can be equally harmful.
Most decent speed shops will stock a zinc (ZDDP) additive that specifies how much should be mixed w/ what types/amount of oil....whether it is GM EOS or something similar.
I'd drain the oil, run a heavier wt diesel oil w/ the a ZDDP additive...makeing sure to prime it good and quickly before initial start up. Good luck!
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
Re: Break in oil
[Re: elmor]
#1282056
08/10/12 12:53 PM
08/10/12 12:53 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Do yourself a favor and get some Brad Penn break in and be done with it. It works, has a crude oil base stock, and will not be any problem whatsoever being a semi synthetic. You dont NEED a dino oil to break an engine in...the internet can be a dangerous place....
RIP Monte Smith
