Shift kit?.
#1281605
08/08/12 03:49 PM
08/08/12 03:49 PM
moparpollack
Lil Herman
Lil Herman
85086
Why are transmission builders so reluctant towards shift kits? It seems the transmission builders either want to set up with a stock transmission or go straight to a manual valve body.
Re: Shift kit?.
[Re: moparpollack]
#1281606
08/08/12 08:19 PM
08/08/12 08:19 PM
I usually find out the intended use and build the transmission to fill the need.
I've used plenty of Trans-Go TF-2's over the years for myself and others but never could get the 2-3 shift where I wanted it.
My latest build for my own ride is a Turbo Action Cheetah full FWD pattern manual Valvebody.
Re: Shift kit?.
#1281607
08/08/12 08:35 PM
08/08/12 08:35 PM
moparpollack
Lil Herman
Lil Herman
85086
It's not a racecar just a driver. Might have to bite the bullet and take a chance.
Re: Shift kit?.
[Re: fox]
#1281612
08/09/12 01:14 PM
08/09/12 01:14 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
One trans guy told me that he couldn't afford the time it takes to get the shift points back near stock!!
A torqueflite is on the hairy edge of overlap/flare STOCK, changing the line pressure, clutch pack clearances and front band apply lever screws it all up and no 2 transmissions will react the same to the same mods. The easy way out is to just put a manual valvebody it in, but if you are going to have to shift the trans you might as well have a manual trans .
Re: Shift kit?.
[Re: JohnRR]
#1281613
08/09/12 09:17 PM
08/09/12 09:17 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
...if you are going to have to shift the trans you might as well have a manual trans .
exactly
