open end rear to limited slip #1281392
08/08/12 12:21 PM
08/08/12 12:21 PM
GA
roadrunninMark Offline OP
GA
I have an 8 3/4 w/ 2.76 gears in it and would like to make it a limited slip rear. I don't want to change gears yet as I like the highway gears. Has anyone should put in some sort of locker, like the Richmond PowerTrax that summit sells? Looks pretty straight forward for the install?
Re: open end rear to limited slip [Re: roadrunninMark] #1281393
08/08/12 02:23 PM
08/08/12 02:23 PM
NE
bigtail Offline
bigtail  Offline
NE
The newest issue of Car Craft (oct - 2012) has a cool article on mixing and matching parts from junkyard 8 3/4s, taking the best from all pigs and combining them into one to get thick tapered pinion, sure grip and 3.91 gears. They did it for less than $400.00.
This page is made up completely of recycled electrons.
Re: open end rear to limited slip [Re: bigtail] #1281394
08/08/12 02:42 PM
08/08/12 02:42 PM
Andrewh Offline
Andrewh  Offline
it wasn't junkyard parts, it was swap meet parts.
they also got to that number figuring out selling the left over parts.
see if dr diff has the parts you need.
Re: open end rear to limited slip [Re: Andrewh] #1281395
08/08/12 02:53 PM
08/08/12 02:53 PM
GA
GA
Sounds good, but I don't want to go playing under junk cars/ scrounging swap meets hoping to get decent parts. I don't have the tools to setting up gears. Nor do I have a press. I thought this was the easiest way to go and the price is just about the same as that article. I am wondering too how easy it would be to install something like this.
Re: open end rear to limited slip [Re: roadrunninMark] #1281396
08/08/12 05:02 PM
08/08/12 05:02 PM
NE
bigtail Offline
bigtail  Offline
NE
Wasn't trying to be a butt. I thought this might be a good alternative to build in your spare time, without any down time to your car until it was ready. Good Luck.
Re: open end rear to limited slip [Re: bigtail] #1281397
08/08/12 10:18 PM
08/08/12 10:18 PM
GA
GA
No offense taken, its all good...
Re: open end rear to limited slip [Re: roadrunninMark] #1281398
08/08/12 10:23 PM
08/08/12 10:23 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
powertrax can be iffy in quality, i know some have had good experiences with them and others have not. I did not have a good experience with them. My dakota slipped one of the their locking rings in the housings so that it would not anymore. That was before my 408 and no nitrous on the truck at the time. I have asked richmond several times what is the maximum horse power and torque these units could take and they would not answer. My truck at the time was making 300 rwhp and about 400 ft lbs torque..
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
