440 SOURCE QUALITY? #1280976
08/07/12 01:21 PM
08/07/12 01:21 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
I just got off the phone with Randy from Prostock,when i asked about 440source stroker kits.....1 word [Edited by Moparts - Family Friendly Site - Keep it clean]!!!I have to respect his opinion ,this guy knows his stuff.
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280977
08/07/12 01:39 PM
08/07/12 01:39 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Re: 440 SOURCE QUALITY? [Re: TOMRR] #1280978
08/07/12 03:10 PM
08/07/12 03:10 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
Meh, got some stuff from them for the 440 I'm putting together.... I suppose the stuff is decent. I guess depending how much is spent towards a given item it gives a bit of insight to the quality of the part. Rule of thumb in some cases I guess.
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280979
08/07/12 03:56 PM
08/07/12 03:56 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
When a vendor slags another vendors stuff, that is a pretty good indication that you need to run not walk away from whatever he is trying to sell you. Guy has no class.
Considering there are thousands of Source kits running around trouble free, mine included, I wouldn't put any more stock in his opinion than he puts in 440Source.
Kevin
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280980
08/07/12 04:01 PM
08/07/12 04:01 PM
AndyF Offline
AndyF  Offline
I wrote a bunch of tech articles over the past 5 years based on a 505 inch big block that was built using 440Source parts. I never had any problems with that 505. It made more than 800 hp on multiple dyno pulls and eventually cracked the main webs. The rotating assembly was still good so we put it into another block and kept running it.
Tech articles are on my website if you want to read them. www.arengineering.com then click on tech articles.
Re: 440 SOURCE QUALITY? [Re: AndyF] #1280981
08/07/12 04:12 PM
08/07/12 04:12 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
I asked who to use and he said scatt is the best of the best
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280982
08/07/12 04:39 PM
08/07/12 04:39 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
There are more then a few good ones out there. I am also using a 440Source stroker kit and just about everything checked out good. The wrist pins were a tad tight in the rods so I honed the rod bushings a bit and they work fine. Everything else was fine. It was no big deal as I would rather have them tight where I can set them to what I like then if they were to loose. Everything is holding up fine and I do race it. Ron
Re: 440 SOURCE QUALITY? [Re: Twostick] #1280983
08/07/12 05:00 PM
08/07/12 05:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I get people who come into my work place fishing to try to get me to talk trash about our competition. I don't. Doing so shows a lack of professionalism. I somehow doubt he was trash talking from first hand experience.
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280984
08/07/12 05:00 PM
08/07/12 05:00 PM
the house on the left.
cogen80 Offline
cogen80  Offline
thats just as Chinese as the 440 source. lol
Re: 440 SOURCE QUALITY? [Re: DaytonaTurbo] #1280985
08/07/12 05:08 PM
08/07/12 05:08 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
he said their parts were chit
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280986
08/07/12 05:45 PM
08/07/12 05:45 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
I'd be willing to bet a nickel he's a Scat vendor.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280987
08/07/12 05:50 PM
08/07/12 05:50 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
My machinist treats them all as cores. Quality control at all the aftermarket parts manufacturing facilities sucks. My source heads had three valves on the tight side an easy fix. When I picked up my motor the new trick flow heads he had five that were tight. Does this make one better than the other? IMHO they all need to be looked at before you assemble anything. The days of bolt on and go are gone.
Re: 440 SOURCE QUALITY? [Re: moparpollack] #1280988
08/07/12 07:14 PM
08/07/12 07:14 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
i'm thinking of just going with the hughes stroker kit and eddy cnc'ed rpm heads,1.6 rockers,girdle and their cam grooved for upper oiling
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280989
08/07/12 08:26 PM
08/07/12 08:26 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
And you will be getting the same chinese crank and rods, with a different name....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 SOURCE QUALITY? [Re: Von] #1280990
08/07/12 09:06 PM
08/07/12 09:06 PM
Manitoba, Canada
Manitoba, Canada
Unless you're going to cough up real money for USA made stuff, you're still buying the same made in china type parts. If Hughes name makes you feel better, go for it.
Re: 440 SOURCE QUALITY? [Re: DaytonaTurbo] #1280991
08/08/12 06:49 AM
08/08/12 06:49 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Scat, what's the definition of that word?
I have no dog in this fight. I've bought from440source and am very happy with the results. But I just have a few hundred miles on it so far.
Re: 440 SOURCE QUALITY? [Re: 68KillerBee] #1280992
08/08/12 10:21 AM
08/08/12 10:21 AM
tboomer Online work
tboomer  Online Work
I have three friends who use the 440 source kits..None have had any problems. I used a Muscle Motors kit. I felt comfortable taking to Mike and Eric at Muscle Motors,they really know their tech stuff and are happy to answer any questions you may have!
Re: 440 SOURCE QUALITY? [Re: tboomer] #1280993
08/08/12 10:43 AM
08/08/12 10:43 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I just got off the phone with someone who asked me what I thought about Walmart. I said their stuff was $%#@!. But I go there 2 - 3 times a week...
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280994
08/08/12 12:24 PM
08/08/12 12:24 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The 440 source kits are good, but not perfect.
On this post below, I detailed the build of my 505" stroked 440 with stealth heads, and CAT rockers.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
So far no problems. I only have about 200 miles on the engine so far.
Re: 440 SOURCE QUALITY? [Re: CUDA8U] #1280995
08/08/12 12:40 PM
08/08/12 12:40 PM
AndyF Offline
AndyF  Offline
SCAT parts work just fine for most bracket race type engines. Do you actually have the money to buy high end parts? If so, I'm sure some folks on here could point you in the right direction. If you're just building bracket motor then any of the stroker kits on the market will work fine. If you have the money to build something serious then I'm sure you can find someone willing to help you out.
