satin black #1280512
08/06/12 06:19 PM
08/06/12 06:19 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..what is the best paint/primer to use for satin black hood treatment?
Re: satin black [Re: can.al] #1280513
08/06/12 08:39 PM
08/06/12 08:39 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
If by "best" you mean top quality, i can't answer that one. If you want cheap, Vansickle satin black looks really good but it may not hold up well. I used it on my Duster hood with the intention of it only being a temporary finish. A friend shot a whole Scion with it, so time will tell whether it chalks up ,peels off, etc. If you want top notch durability, probably any good urethane with flattener added would be best.
Re: satin black [Re: forphorty] #1280514
08/06/12 11:22 PM
08/06/12 11:22 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
DouPont hot rod black not bad.single stage enamel.
Re: satin black [Re: stinger] #1280515
08/07/12 07:02 AM
08/07/12 07:02 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Use the same brand primer as your paint.. Hard to beat Krylon..
I am truckless..
Re: satin black [Re: 340SHORTY] #1280516
08/07/12 07:23 AM
08/07/12 07:23 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
http://semproducts.com/product-catalog/color-horizons/hot-rod/hot-rod-black/
It was dusty for sitting disassembled. When I got the hood/fenders on a week or so ago I went over the hood with Meguiar's quick detailer. Sprayed, wiped with towel to get dust, wiped with another towel to clean off haze. Looks great.
Crappy cell phone pic.
383, Hemi 4-Speed, AlterKtion, D60
Re: satin black [Re: Crazy68Dart] #1280517
08/07/12 09:29 AM
08/07/12 09:29 AM
Port Saint Lucie, FL
ChallengerGary Offline
I have sprayed Rustoleum Satin Black with a gun with great results. Thinned it with a little acetone. It coats very well and by using low enough pressure you can actually get a little bit of the organisol texture to it. Plus, it is really hard to beat the price
Re: satin black [Re: can.al] #1280518
08/07/12 10:25 AM
08/07/12 10:25 AM
Illinois
Mopar_Ray Offline
Mopar_Ray  Offline
Illinois
Another vote for the "SEM Products Color Horizons Hot Rod Black" Used a couple of times. Comes out pretty nice.
http://www.summitracing.com/parts/SMM-HR010
Re: satin black [Re: Mopar_Ray] #1280519
08/07/12 11:15 AM
08/07/12 11:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
My guy used "hot rod" black as well.
Coming soon!!!!
Re: satin black [Re: Mr.Yuck] #1280520
08/08/12 11:23 AM
08/08/12 11:23 AM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
i thought that I had read the hood treatment was done in organisol. This was in reference to a 69 roadrunner. Should it be Satin???
Re: satin black [Re: TrueTripleX] #1280521
08/08/12 12:18 PM
08/08/12 12:18 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You are correct Organisol was used originally. I think these guys are not concerned with original, just looking to paint a satin black accent on the car.Here is organisol on the hood of my 70 RR
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: satin black [Re: MOPARMIKE69] #1280522
08/09/12 08:00 AM
08/09/12 08:00 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Could you use Base Coat and then a matte clear? I am trying to figure this out for a paint scheme on my father's 74 Barracuda (aar style paint)
Re: satin black [Re: wally426ci] #1280523
08/09/12 08:43 AM
08/09/12 08:43 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
yes you can but unless your a painter with the tint and binder and hardner its a little bit to get the right look. I've used base and flatner tint in the clear with good results but do sprayouts of the mix before you paint the car.
