I want 5" steel wheels #1280212
08/06/12 12:27 AM
08/06/12 12:27 AM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
Is there a 5" wheel available with the same(or close) backspacing as my stock 15x7 steelies?
Re: I want 5" steel wheels [Re: west] #1280213
08/06/12 10:05 AM
08/06/12 10:05 AM
nj
MoJoe Offline
MoJoe  Offline
nj
Check wheel and tires for sale Junkyardmaxie has 2 15x5.5 that look pretty nice.
Re: I want 5" steel wheels [Re: west] #1280214
08/06/12 12:34 PM
08/06/12 12:34 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Yes there is such an animal, I have them on the front of my Challenger. The wheels had a 34xxxxx part # writen on them but I do not remember the rest of the number. They are 15X5 and were sold by Chrysler. The 34xxxxx part # would make it a 1971 Wheel off some low performance model.
1971 HEMI E BODY REGISTRY
Re: I want 5" steel wheels [Re: hemicar1971] #1280215
08/06/12 02:20 PM
08/06/12 02:20 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
When I said the same backspacing what I meant was the end result would sit in the wheel well the same way. Obviously the backspacing would be different if that's the case because it is a smaller wheel. I assume you knew that is what i meant but I wanted to clear it up.
I also forgot to mention I wanted a big bolt pattern.
Would you say the outside of your wheel is in the same place? Do you know how many inches of backspace your wheels have?
Thanks for the reply.
Re: I want 5" steel wheels [Re: west] #1280216
08/06/12 09:05 PM
08/06/12 09:05 PM
I have a set of (4) nice 15" steelies that are BBP and 5" wide. I remember seeing a kelsey hayes logo and the PO said they were from a ford thunderbird. PM if interested & I'll get the backspacing for you
Re: I want 5" steel wheels [Re: RapidRobert] #1280217
08/06/12 09:40 PM
08/06/12 09:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Robert, check the center hole; Ford wheels used to have a smaller spindle hole than Mopars. Wasn't a problem on Magnum 500s, but the basic steelies wouldn't fit Mopar spindles or axle registers.
Re: I want 5" steel wheels [Re: topside] #1280218
08/06/12 11:31 PM
08/06/12 11:31 PM
Thank you, I will check em. EDIT 3&3/4" BS. A hair under 2&5/8" center hole dia.
Re: I want 5" steel wheels [Re: west] #1280219
08/06/12 11:49 PM
08/06/12 11:49 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
The 5" wheels that I used came off an early B van. It was a slant 6 powered van with 15" x 5" wheels. They have a modern steel wheel look and are a good match for the 8" ramcharger rims.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: I want 5" steel wheels [Re: racealittle] #1280220
08/07/12 12:33 AM
08/07/12 12:33 AM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
Some are saying 5" and others are say 5 1/2"
Were both sizes available in a large bolt pattern?
I need a pair of 5" in Ca.
Re: I want 5" steel wheels [Re: west] #1280221
08/07/12 12:40 AM
08/07/12 12:40 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The ones I have are 5.5". They came off an '82 D150 with a slant six and had 195-75-15 tires on them.
