WHAT PISTON ARE THESE?? #1279624
08/05/12 12:56 AM
08/05/12 12:56 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Ive had these pistons for about 10yrs, some guy gave them to me. He said they were for a 440, there is no name on them. Just says .040 over. Inside there are 2 marking an arrow on one side and a triangle with a - on the other. There are 4 valve notches and a 1/4 of it is raised up higher. They measure about 4 5/16. Is there anyway to figure out what kind they are?
Re: WHAT PISTON ARE THESE?? [Re: moon] #1279625
08/05/12 12:58 AM
08/05/12 12:58 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
2nd pic
Re: WHAT PISTON ARE THESE?? [Re: moon] #1279626
08/05/12 12:59 AM
08/05/12 12:59 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
3rd pic
Re: WHAT PISTON ARE THESE?? [Re: moon] #1279627
08/05/12 01:00 AM
08/05/12 01:00 AM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
4th pic
Re: WHAT PISTON ARE THESE?? [Re: moon] #1279628
08/05/12 07:09 AM
08/05/12 07:09 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Besides the .040 there appears to be some numbers on the top. What are those numbers?
Re: WHAT PISTON ARE THESE?? [Re: TooMany62s] #1279629
08/05/12 07:22 AM
08/05/12 07:22 AM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
To me they look like a 440 6PAK piston cut down
Re: WHAT PISTON ARE THESE?? [Re: Bishop] #1279630
08/05/12 10:35 AM
08/05/12 10:35 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
They do don't they??
Re: WHAT PISTON ARE THESE?? [Re: Dodgem] #1279631
08/05/12 12:19 PM
08/05/12 12:19 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
X3 someone flycut the top of that piston.
Re: WHAT PISTON ARE THESE?? [Re: JohnRR] #1279632
08/05/12 12:45 PM
08/05/12 12:45 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
they look like a '70 six pak piston that has been milled to reduce compression but still have a quench pad for closed chamber heads. the first time i've heard of this was edelbrock doing it on a dyno mule engine. probably would work fine on an 84cc or 74cc edelbrock head. i wouldn't be afraid to use them. measure the cut and you can come close to calculating a compression ratio.
Re: WHAT PISTON ARE THESE?? [Re: lewtot184] #1279633
08/05/12 01:53 PM
08/05/12 01:53 PM
AZ, USA
moon Offline OP
moon  Offline OP
AZ, USA
Here's a pic with the letters
Re: WHAT PISTON ARE THESE?? [Re: moon] #1279634
08/05/12 02:53 PM
08/05/12 02:53 PM
JohnRR Offline
JohnRR  Offline
The LH I'll ASSuME is LEFT HAND , that would be on 4 pistons , 4 should have RH , unless it was milled off .
Not to come off like an [Edited by Moparts - Family Friendly Site - Keep it clean] but using a dial or digital caliper can you measure the piston diameter, the height from the top of the pin bore to the top of the piston and the depth of that step? That will help determine what the piston is instead of a just a picture and a measurement using what I assume was a 25ft tape measure?
Re: WHAT PISTON ARE THESE?? [Re: moon] #1279635
08/05/12 03:06 PM
08/05/12 03:06 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
It does look like someone spent too much time making a set of ashtrays. They made a 9.5 compression piston into a 8-1 piston. At least they are a little better weight now.
Sheldon
