Re: WHAT PISTON ARE THESE??
[Re: moon]
#1279625
08/05/12 12:58 AM
08/05/12 12:58 AM
Posts: 136 AZ, USA
moon
AZ, USA
[Re: moon]
#1279626
08/05/12 12:59 AM
08/05/12 12:59 AM
Posts: 136 AZ, USA
moon
AZ, USA
[Re: moon]
#1279627
08/05/12 01:00 AM
08/05/12 01:00 AM
Posts: 136 AZ, USA
moon
AZ, USA
[Re: Dodgem]
#1279631
08/05/12 12:19 PM
08/05/12 12:19 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
They do don't they??
X3 someone flycut the top of that piston.
[Re: moon]
#1279634
08/05/12 02:53 PM
08/05/12 02:53 PM
JohnRR
U.S.S.A.
Here's a pic with the letters
The LH I'll ASSuME is LEFT HAND , that would be on 4 pistons , 4 should have RH , unless it was milled off .
Not to come off like an [Edited by Moparts - Family Friendly Site - Keep it clean] but using a dial or digital caliper can you measure the piston diameter, the height from the top of the pin bore to the top of the piston and the depth of that step? That will help determine what the piston is instead of a just a picture and a measurement using what I assume was a 25ft tape measure?
