440 fuel pump bolts...teflon tape...loctite? #1279231
08/04/12 03:57 PM
08/04/12 03:57 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
Slowly putting parts back on the 440 and getting ready for the install.
Fuel pump time, do I need to put teflon tape or loctite on the bolts?
Thanks.
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: KillerBee] #1279232
08/04/12 04:03 PM
08/04/12 04:03 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
no
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: 65rbdodge] #1279233
08/04/12 05:14 PM
08/04/12 05:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
No
I am truckless..
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: 340SHORTY] #1279234
08/04/12 08:02 PM
08/04/12 08:02 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
(in case you missed the above posts.... no
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: KillerBee] #1279235
08/05/12 10:57 AM
08/05/12 10:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
the bolts are open in the housing , , me personally I always put some kind of locktite sealer on them to prevent oil weeping up the threads.
new bolts have a thread sealer / lock tight on them btw
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: gtx6970] #1279236
08/05/12 11:33 AM
08/05/12 11:33 AM
N.E. Ohio
K
K
N.E. Ohio
That's what I was thinking
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: KillerBee] #1279237
08/05/12 12:13 PM
08/05/12 12:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Loctite or thread sealer but definitely NOT Teflon tape .
I usually just run them in dry , never seen a leak there .
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: JohnRR] #1279238
08/05/12 12:44 PM
08/05/12 12:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Right, NOT teflon tape!
I just reinstalled a fuel pump about 2 weeks ago put the the bolts in dry. Drove the car over 500 miles since then. 75 miles yesterday!
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: KillerBee] #1279239
08/05/12 03:12 PM
08/05/12 03:12 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
When there are fluids involved and vibration/loosening is not the main concern, I sparingly apply Black Permatex Ultraseal to clean threads & both sides of the gasket surface, being sure to wipe off any excess that may squeeze out once tightened.
The trick is to use only a thin film on mating surfaces and just enough to fill the threads on the bolts. When done correctly, you won't even have to wipe the excess, as there won't be any.
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: jbc426] #1279240
08/05/12 03:30 PM
08/05/12 03:30 PM
md
mopars4ever Offline
mopars4ever  Offline
md
with the above post
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: mopars4ever] #1279241
08/05/12 03:52 PM
08/05/12 03:52 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
never used anything ,never had a leak.
Re: 440 fuel pump bolts...teflon tape...loctite? [Re: bonefish] #1279242
08/05/12 07:32 PM
08/05/12 07:32 PM
Me TOO, the original bolts have a nylon insert in them, it seals and and acts as locktite material also
