'73 Fury upgrade - asking for help and recommendations #1278952
08/04/12 06:32 AM
08/04/12 06:32 AM
HemiFury1973 Offline OP
Hi Guys,
I have 1973 Plymouth fury Gran Sedan 400/727 that i want to upgrade to have more power and especially throttle response.
I would like to change carb to Hollry 4bbl and of course change the intake manifold, camshaft and timing set.
I don't know which configuratios to choose and i would appreciate your help and recommendations.
Regards,
Hemi (Yes, this is my name)
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278953
08/04/12 07:50 AM
08/04/12 07:50 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
What carb do you have on it now? 2bbl?
A small Edelbrock 4bbl (600 or 650) on a Edelbrock Performer intake will help some along with some headers.
I wouldn't go throwing a cam at it without knowing exactly what's in it now for pistons, compression ratio, etc. You could really kill the power that way.
Re: '73 Fury upgrade - asking for help and recommendations [Re: bobs66440] #1278954
08/04/12 08:50 AM
08/04/12 08:50 AM
Thank you.
For now i have 2bbl Holley. I don't know the rest details.
So can i for now vhange only the carb and intake and later add a mild cam (Lunati 60302 for instance)?
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278955
08/04/12 10:36 AM
08/04/12 10:36 AM
RapidRobert Online content
RapidRobert  Online Content
Welcome aboard! For starters I'd change the timing gear set to a new one with multiple 4 deg keyways & advance it 4 degrees and tweak the dist: set initial with vacuum gauge method/shorten slots to 38 total (no vac)/toss heavy spring/replace it with a light one/plug in vac adv & turn it CW with a 3/32" allen wrench to make it come in sooner. '73 model year was a terrible one for emission regs & you could go richer on the 2bbl jets. This'd give you a good boost without alot of down time.
Re: '73 Fury upgrade - asking for help and recommendations [Re: RapidRobert] #1278956
08/04/12 07:17 PM
08/04/12 07:17 PM
Central NC
gch Online content
gch  Online Content
Central NC
First thing I would do is dual exhaust.2.25 or 2.5 pipe.
Then richen up the jets or install a small 4 bbl of your choosing.
Getting lighter advance springs in the distibutor will help acceleration.
Running a 160 or 180 thermostat will help it run cooler and make good power.
A cam is not necessary but if you do it go small.400's don't make a lot of low end and a big cam will leave you disappointed.
Finding your rear gear ratio will help you determine the best mods.
A well tuned 400(new plugs,good wires,and distributor work will make a huge difference and give you a solid foundation for any mods.
Nice car BTW.
Re: '73 Fury upgrade - asking for help and recommendations [Re: gch] #1278957
08/05/12 03:09 PM
08/05/12 03:09 PM
Thank you.
How can i find the gear ratio?
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278958
08/05/12 03:51 PM
08/05/12 03:51 PM
jack 1 rear tire just off the ground and place gearshift in neutral. put tire valve stem at 6 o'clock then rotate tire 2 revolutions & count # of driveshaft turns, ie 2&3/4 turns is 2.76. If you have a sure grip jack both rear tires just off the ground and rotate them 1 revolution & count the driveshaft turns
Re: '73 Fury upgrade - asking for help and recommendations [Re: RapidRobert] #1278959
08/06/12 08:48 PM
08/06/12 08:48 PM
Central NC
gch Online content
gch  Online Content
Central NC
It may still have the factory tag with the ratio stamped on it.
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278960
08/07/12 12:04 PM
08/07/12 12:04 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Thank you.
assuming it's a 2.76ish rear, I'd probably look at the voodoo 60301
2017 Grand Cherokee Overland
Re: '73 Fury upgrade - asking for help and recommendations [Re: gch] #1278961
08/07/12 02:23 PM
08/07/12 02:23 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
On t he cheap I'd call summit and grab the smaller 455 cam and a T-chain set. I'd also run some dual exhaust and up the rear gear to 3.23. As for intake I'd try and find a DP4B or Holley SD. I'd run a 4 hole 1/2" spacer and a small holley or 625 carter. That should wake it up plenty and it won't hurt your mpg...if that's a concern.
Coming soon!!!!
Re: '73 Fury upgrade - asking for help and recommendations [Re: Mr.Yuck] #1278962
08/07/12 06:26 PM
08/07/12 06:26 PM
IL
furious70 Offline
furious70  Offline
IL
Holley SD intake will take all the low end torque away, I tried it several different ways on my 383. In the great intake dyno test it was down something like 30ft lbs @3000rpm to a dp4b, imagine how bad it was way down low.
when it was still NA and carb'ed, my car had a lot more grunt from an idle with the stock intake and 3.23's then it did with the SD and 3.91's.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: '73 Fury upgrade - asking for help and recommendations [Re: furious70] #1278963
08/07/12 07:56 PM
08/07/12 07:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
did you have the open or dual plane SD? i was talking about the low profile dual plane
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278964
08/23/12 02:54 PM
08/23/12 02:54 PM
Thanks.
The gear ratio is 2.71...
What next? :-)
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278965
08/23/12 08:08 PM
08/23/12 08:08 PM
dogdays Offline
dogdays  Offline
The '73 is BUILT rich, the 2-barrel is choking the engine.
Ditch the 2-barrel and the carb. Buy a new Holley 670 Street Avenger and an Edelbrock Performer RPM.
A 400 is basically a larger bore 383 with low compression. You can definitely go too big, again I say the second Voodoo cam from the smallest would do all right.
Get your exhaust system right. If you can't find HP exhaust manifolds for it you can use the low perf ones but go to 2 1/2" system from manifold to rear end, using two Dynomax 17748 or 17749 Hemi Turbos. Be sure to put in an H-pipe, that's a pipe connecting the exhaust pipes to each other, should be the same diameter and as far forward as will fit.
With all my changes you'll pick up at least 50 hp with no decrease in fuel mileage, probably an increase. The car will feel completely different. It's amazing what a simple 4-barrel swap can do.
R.
Re: '73 Fury upgrade - asking for help and recommendations [Re: dogdays] #1278966
08/24/12 03:11 PM
08/24/12 03:11 PM
R.
Thank you so much.
But will 670 not be too big for the engine?
And the intake - Edel brock rpm will be better than weiand with the Holley carb?
Hemi
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278967
08/24/12 03:39 PM
08/24/12 03:39 PM
So, what should i choose?
carb: Holley 570 or 670?
Intake manifold: Weiand 8008 or Edelbrock performer?
Thanks,
Hemi
Re: '73 Fury upgrade - asking for help and recommendations [Re: bobs66440] #1278968
08/25/12 01:03 PM
08/25/12 01:03 PM
The compression ratio is 8.2, rear end 2.71.
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278969
08/25/12 08:58 PM
08/25/12 08:58 PM
Central NC
gch Online content
gch  Online Content
Central NC
Performer and 570 if you are keeping the 2.71 gears.
Re: '73 Fury upgrade - asking for help and recommendations [Re: gch] #1278970
10/15/12 03:12 PM
10/15/12 03:12 PM
So, at last I bought a 670 street avenger holley carb along with weiand action plus intake manifold and a new mopar performance ignition kit and new plugs. Now it's time to put all them on :-)
Re: '73 Fury upgrade - asking for help and recommendations [Re: HemiFury1973] #1278971
10/15/12 04:40 PM
10/15/12 04:40 PM
If it comes with an orange box I would suggest keeping a spare 4 pin ECU in the glove box. Your parts house has em for cheap. I'm assuming you already have electronic ign. I'd get a hotter coil/ballast. I use a FBO coil and MP 1/4 ohm ballast and OE ECU & it starts/runs awesome. the power is pretty much from the coil/ballast combo & not the coil primary switcher (ECU) but people are raving about FBO's new ECU. EDIT If needed there is a pentastar ECU harness/pigtail assy for $28 in the BB for sale section page 6 which may or may not come with the 2 terminal nominal 1.25 ohm ballast but was not shown in the pic
