Re: '73 Fury upgrade - asking for help and recommendations
[Re: HemiFury1973]
#1278955
08/04/12 10:36 AM
08/04/12 10:36 AM
RapidRobert
Welcome aboard! For starters I'd change the timing gear set to a new one with multiple 4 deg keyways & advance it 4 degrees and tweak the dist: set initial with vacuum gauge method/shorten slots to 38 total (no vac)/toss heavy spring/replace it with a light one/plug in vac adv & turn it CW with a 3/32" allen wrench to make it come in sooner. '73 model year was a terrible one for emission regs & you could go richer on the 2bbl jets. This'd give you a good boost without alot of down time.
[Re: gch]
#1278957
08/05/12 03:09 PM
08/05/12 03:09 PM
HemiFury1973
Finding your rear gear ratio will help you determine the best mods.
Thank you. How can i find the gear ratio?
[Re: HemiFury1973]
#1278958
08/05/12 03:51 PM
08/05/12 03:51 PM
RapidRobert
jack 1 rear tire just off the ground and place gearshift in neutral. put tire valve stem at 6 o'clock then rotate tire 2 revolutions & count # of driveshaft turns, ie 2&3/4 turns is 2.76. If you have a sure grip jack both rear tires just off the ground and rotate them 1 revolution & count the driveshaft turns
[Re: Mr.Yuck]
#1278962
08/07/12 06:26 PM
08/07/12 06:26 PM
Posts: 2,252 IL
furious70
IL
Holley SD intake will take all the low end torque away, I tried it several different ways on my 383. In the great intake dyno test it was down something like 30ft lbs @3000rpm to a dp4b, imagine how bad it was way down low.
when it was still NA and carb'ed, my car had a lot more grunt from an idle with the stock intake and 3.23's then it did with the SD and 3.91's.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#1278963
08/07/12 07:56 PM
08/07/12 07:56 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
did you have the open or dual plane SD? i was talking about the low profile dual plane
[Re: HemiFury1973]
#1278965
08/23/12 08:08 PM
08/23/12 08:08 PM
dogdays
The '73 is BUILT rich, the 2-barrel is choking the engine.
Ditch the 2-barrel and the carb. Buy a new Holley 670 Street Avenger and an Edelbrock Performer RPM.
A 400 is basically a larger bore 383 with low compression. You can definitely go too big, again I say the second Voodoo cam from the smallest would do all right.
Get your exhaust system right. If you can't find HP exhaust manifolds for it you can use the low perf ones but go to 2 1/2" system from manifold to rear end, using two Dynomax 17748 or 17749 Hemi Turbos. Be sure to put in an H-pipe, that's a pipe connecting the exhaust pipes to each other, should be the same diameter and as far forward as will fit.
With all my changes you'll pick up at least 50 hp with no decrease in fuel mileage, probably an increase. The car will feel completely different. It's amazing what a simple 4-barrel swap can do.
R.
[Re: dogdays]
#1278966
08/24/12 03:11 PM
08/24/12 03:11 PM
HemiFury1973
R.
Thank you so much. But will 670 not be too big for the engine? And the intake - Edel brock rpm will be better than weiand with the Holley carb?
Hemi
[Re: bobs66440]
#1278968
08/25/12 01:03 PM
08/25/12 01:03 PM
HemiFury1973
What carb do you have on it now? 2bbl?
A small Edelbrock 4bbl (600 or 650) on a Edelbrock Performer intake will help some along with some headers.
I wouldn't go throwing a cam at it without knowing exactly what's in it now for pistons, compression ratio, etc. You could really kill the power that way.
The compression ratio is 8.2, rear end 2.71.
[Re: HemiFury1973]
#1278971
10/15/12 04:40 PM
10/15/12 04:40 PM
RapidRobert
and a new mopar performance ignition kit
If it comes with an orange box I would suggest keeping a spare 4 pin ECU in the glove box. Your parts house has em for cheap. I'm assuming you already have electronic ign. I'd get a hotter coil/ballast. I use a FBO coil and MP 1/4 ohm ballast and OE ECU & it starts/runs awesome. the power is pretty much from the coil/ballast combo & not the coil primary switcher (ECU) but people are raving about FBO's new ECU. EDIT If needed there is a pentastar ECU harness/pigtail assy for $28 in the BB for sale section page 6 which may or may not come with the 2 terminal nominal 1.25 ohm ballast but was not shown in the pic
