Is there any way abody tti header will work on a ebody #1278765
08/03/12 03:12 PM
08/03/12 03:12 PM
ME
79machocharger Offline OP
ME
Found a good deal on a set of nice tti headers for an abody and was wondering if theres any way these will fit an ebody?
Thanks for any help
Re: Is there any way abody tti header will work on a ebody [Re: 79machocharger] #1278766
08/03/12 03:23 PM
08/03/12 03:23 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
I would think they would as they would fit a little tighter to the engine in the A body , but if that were the case TTi wouldn't have made them chassis specific ???
Re: Is there any way abody tti header will work on a ebody [Re: JohnRR] #1278767
08/03/12 04:05 PM
08/03/12 04:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Just some ideas/guesses on areas of concern...
-The motor mounts are way different A to B/E body. Just one thing poking out in the wrong direction could justify a specific design.
-I think the suspension linkage on an E/B body sets further forward or there is more room for the header/headpipes to move back. This is why you can run long quick ratio "T/A" pitmans and idlers on a E/B with stone stock and some headers. But on an A-body you can't, the pitman/idleer/centerlink will run into the headpipe or header down tubes.
-Also IF (just an IF) the engine sit for and aft different in relationship between the steering box there could be an issue there too between A and B/E. The TTI headers snake around the steering box, especially power steering.
Now, maybe there is still room on a E/B for these A-body headers without long pitman. I dunno. Just suggesting those are three areas that jump out at me for concern that you might start measuring first.
Re: Is there any way abody tti header will work on a ebody [Re: 79machocharger] #1278768
08/03/12 04:12 PM
08/03/12 04:12 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Thanks for any help
Small block? Big block?
Re: Is there any way abody tti header will work on a ebody [Re: Dcuda69] #1278769
08/03/12 08:58 PM
08/03/12 08:58 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
No they won't work.
Re: Is there any way abody tti header will work on a ebody [Re: west] #1278770
08/03/12 09:08 PM
08/03/12 09:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: Is there any way abody tti header will work on a ebody [Re: 79machocharger] #1278771
08/03/12 10:00 PM
08/03/12 10:00 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
If it's a small block than the passenger sides are the same. The driver's side is different enough that it won't fit. When my Duster got totaled I saved the headers for my 'Cuda. TTI sold me a driver's side header for half the price of a full set.
Re: Is there any way abody tti header will work on a ebody [Re: 5spdcuda] #1278772
08/03/12 10:17 PM
08/03/12 10:17 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Call TTI and ask them.
If they worked, I would imagine they would sell the same P/N for multiple chassis.
383, Hemi 4-Speed, AlterKtion, D60
Re: Is there any way abody tti header will work on a ebody [Re: Crazy68Dart] #1278773
08/04/12 09:54 AM
08/04/12 09:54 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Ask the manufacturer? Way too simple!
Re: Is there any way abody tti header will work on a ebody [Re: 79machocharger] #1278774
08/04/12 10:40 AM
08/04/12 10:40 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Is there any way abody tti header will work on a ebody [Re: 79machocharger] #1278775
08/04/12 03:05 PM
08/04/12 03:05 PM
Locomotion Offline
Locomotion  Offline
Thanks for any help
Ryan,
You have a PM and email about a friend who may be able to help.
Re: Is there any way abody tti header will work on a ebody [Re: Locomotion] #1278776
08/05/12 10:12 AM
08/05/12 10:12 AM
ME
ME
Called tti and talked to them, and actually ended up ordering a new set through them for an ebody as they said the abody ones there is no way to make them work.
