Well I came up with a solution (I should say Sean
and myself did, Sean is the builder over where I will
be getting it dynoed)..I had him stop by my place
to see what was going on... the lifter bushings are
a little loose ... I'll have him push out the old bushings
and install new ones but leave them .300 tall...
this will correct the loose bores and the hole being
exposed a bit... that will still clear the tie bar
on the lifter..... right now there is way to much
oil coming out of the lifter bores... so doing it
this way I wont have to touch the cam...... so I'll
tear it back apart tomorrow and take it to him Monday...
the pistons are gonna be wore out just by taking
them in and out..... this is getting OLD
