Re: cluster voltage regulator issue
[Re: woody02]
#1277456
08/01/12 11:37 AM
08/01/12 11:37 AM
RapidRobert
What Andrew said, I dont think 2 of the terminals are supposed to be spliced together & I'm wondering why someone had done that. Any possibility you can get the correct one?
[Re: woody02]
#1277462
08/02/12 10:57 AM
08/02/12 10:57 AM
Andrewh
so the 2 pin is just 12 volt power. the other single pin is 5 volts out. ground is the case, there is a cut out on one side that it bolts to the ground. in the http://rt-eng.com/rte/index.php/RTE_Limiter_Faqpart way down you can see he has lables on it wired up.
