cluster voltage regulator issue #1277454
08/01/12 10:36 AM
08/01/12 10:36 AM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
there are three terminals on my voltage limiter.2 terminals are spliced together.the third is a stand alone.is the stand alone terminal 12v in. and the two shared terminals go to gauges.i have a pic of it all wired together if someone can make since of it. i think it may be wired up wrong. also the is a capisitor looking thing that goes to one of the terminals
i kinda wanted to get this wrapped up by the weekend. i found a replacement regulator,but it has 2 terminals and mounts different.
Re: cluster voltage regulator issue [Re: woody02] #1277455
08/01/12 11:14 AM
08/01/12 11:14 AM
Andrewh Online content
Andrewh  Online Content
you didn't specify car or type of gauges, so generically, there are 3 prongs on the instrument vr.
1 end is attached to the outside case and is ground.
the middle has a capacitor pinned into the board with it and is 12 volts from the plug.
the third supplies the gauges with 5 volts.
so if you have any of the 2 wired together you either are supplying 12 volts to the gauges, or are running a dead short.
the ralley type should work the same, but I am unfamilar with how they are hooked into the gauges.
Re: cluster voltage regulator issue [Re: woody02] #1277456
08/01/12 11:37 AM
08/01/12 11:37 AM
What Andrew said, I dont think 2 of the terminals are supposed to be spliced together & I'm wondering why someone had done that. Any possibility you can get the correct one?
Re: cluster voltage regulator issue [Re: RapidRobert] #1277457
08/01/12 04:04 PM
08/01/12 04:04 PM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
its a factory splice.what i mean is 2 of the spaids are put together with one rivit,the other spaid is by itself. i have pics if that helps.i just need to send them to you from my phone.
Re: cluster voltage regulator issue [Re: woody02] #1277458
08/01/12 04:05 PM
08/01/12 04:05 PM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
i guess i should mention its a 73 challenger with rally gauges. i.e tach/clock,ect
Re: cluster voltage regulator issue [Re: woody02] #1277459
08/01/12 04:35 PM
08/01/12 04:35 PM
yeah, you are going to have to show a pic. doesnt make sense.
here are some dash vr links though.
http://www.moparts.org/Tech/Archive/elec/11.html
http://rt-eng.com/rte/index.php/RTE_Limiter_Faq
Re: cluster voltage regulator issue [Re: Andrewh] #1277460
08/01/12 04:37 PM
08/01/12 04:37 PM
Re: cluster voltage regulator issue [Re: Andrewh] #1277461
08/02/12 10:51 AM
08/02/12 10:51 AM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
Yrs andrewh that's what I got
Re: cluster voltage regulator issue [Re: woody02] #1277462
08/02/12 10:57 AM
08/02/12 10:57 AM
so the 2 pin is just 12 volt power.
the other single pin is 5 volts out.
ground is the case, there is a cut out on one side that it bolts to the ground.
in the
part way down you can see he has lables on it wired up.
Re: cluster voltage regulator issue [Re: Andrewh] #1277463
08/06/12 11:42 AM
08/06/12 11:42 AM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
well i just bought a 2 terminal solid state ivr3. my question now is what terminal gets the 12 v and which goes to gauges as 5v.one of the terminal has an adjustment screw next to it.is that the 5v terminal?
Re: cluster voltage regulator issue [Re: woody02] #1277464
08/06/12 11:44 AM
08/06/12 11:44 AM
michigan,usa
W
woody02 Offline OP
woody02  Offline OP
W
michigan,usa
i forgot to mention andrew the 2 terminal is the updated version of the 3 terminal.i no longer need the capaciter according to instructions.now i need to figure out what terminal goes where
Re: cluster voltage regulator issue [Re: woody02] #1277465
08/06/12 12:25 PM
08/06/12 12:25 PM
didn't this help?
