Can you measure bore with telescoping gauges & calipers #1277178
07/31/12 05:25 PM
07/31/12 05:25 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
I picked up some telescoping gauges and a digital caliper that measures to .001.
I spent only about 20 minutes and got consistent readings with these tools. I understand there is a process to measure for taper and out of round. I didn't want to waste a whole bunch of time if this method is not reliable.
For example, I'm checking the bore on a 318, the spec says 3.910 to 3.912 is the standard bore. I got 3.9060 consistently in three of the cylinders. That gives me .004, the maximum tolerance is over .005 before requiring reconditioning.
Anyone use these tools for this?
Re: Can you measure bore with telescoping gauges & calipers [Re: cudabitten] #1277179
07/31/12 07:36 PM
07/31/12 07:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If you are measuring at 3.906 you are measuring smaller than the standard 3.91-3.92 not .004 wear.
3.91 is bigger than 3.906 unless new math changed things
Re: Can you measure bore with telescoping gauges & calipers [Re: MoparforLife] #1277180
07/31/12 10:57 PM
07/31/12 10:57 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Not gonna give you what you really need to know, find someone with a bore guage. And don't get to hung up on the .005 thing, looser still works, just makes a little more noise....
Re: Can you measure bore with telescoping gauges & calipers [Re: cudabitten] #1277181
07/31/12 11:41 PM
07/31/12 11:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you had a standard to calibrate the digital calipers it might be halfway accurate to use them and the snap gauges, without it your guessing how far the calipers are out from being accurate at any size See if you can borrow or buy a 2,3 and 4 inch outside micrometer checking tool, standard, to work with now And use both the snap gauges and the calipers to measure both the bores and pistons
Re: Can you measure bore with telescoping gauges & calipers [Re: cudabitten] #1277182
08/01/12 01:19 AM
08/01/12 01:19 AM
Illinois
fishy68 Offline
fishy68  Offline
Illinois
Moparforlife nailed it. You said you measured 3.906". That's .004" smaller than the minimum. That right there should tell you it's not accurate. The biggest problem is probably the caliper. I have 3 and none read the same. Their all within 2-3 thousandths which is ok for most things but not all.
68 Cuda 408/904/8-3/4
02 Dakota 4.7 auto
Re: Can you measure bore with telescoping gauges & calipers [Re: fishy68] #1277183
08/01/12 04:16 AM
08/01/12 04:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have a full set of telescoping gauges I use. I have digital calipers and outside mikes up to 5 inches. The mikes are dead accurate as I check them and calibrate them all the time. The digital caliper is very accurate as I can also calibrate it. The thing is you need a good touch with telescoping gauges to be very accurate. I like to use them for general readings but use my bore gauge for very accurate readings. Ron
Re: Can you measure bore with telescoping gauges & calipers [Re: 383man] #1277184
08/01/12 08:41 AM
08/01/12 08:41 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
I agree 100%.. Mikes and a good feel for the telescope gauge. Dial bore gauges are dead on.
Re: Can you measure bore with telescoping gauges & calipers [Re: cudabitten] #1277185
08/01/12 01:03 PM
08/01/12 01:03 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The snap gauge and calipers could be OK for a rough measurement, but don't have the accuracy required for most inside measurements on an engine where you would want at least 0.0005" resolution or better for measuring main, rod and piston bore clearances.
A dial bore gauge is a comparison tool. It is setup using a known standard, usually a calibrated micrometer.
Re: Can you measure bore with telescoping gauges & calipers [Re: 451Mopar] #1277186
08/01/12 07:51 PM
08/01/12 07:51 PM
dogdays Offline
dogdays  Offline
Unless your snap gauges have rounded ends you will be measuring slightly under the bore size. Like this: (!---!)
I really don't like snap gauges and after using a good bore gauge I am spoiled.
R.
Re: Can you measure bore with telescoping gauges & calipers [Re: dogdays] #1277187
08/02/12 12:31 AM
08/02/12 12:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
R.
Mine do have rounded ends on all of them. Ron
Re: Can you measure bore with telescoping gauges & calipers [Re: 383man] #1277188
08/02/12 09:01 AM
08/02/12 09:01 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
go to your local parts store that rents tools,get the right size Mic,for the standard if nothing else.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Can you measure bore with telescoping gauges & calipers [Re: runinonmt] #1277189
08/02/12 09:33 AM
08/02/12 09:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Snap gauges work fine, but it's one of those things that work fine if you have a lots of practice using them. A bore gauge is more user friendly, especially for someone who doesn't do it often enough.
Don't be the exception.
