Re: Can you measure bore with telescoping gauges & calipers
[Re: cudabitten]
#1277181
07/31/12 11:41 PM
07/31/12 11:41 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
If you had a standard to calibrate the digital calipers it might be halfway accurate to use them and the snap gauges, without it your guessing how far the calipers are out from being accurate at any size See if you can borrow or buy a 2,3 and 4 inch outside micrometer checking tool, standard, to work with now And use both the snap gauges and the calipers to measure both the bores and pistons
[Re: cudabitten]
#1277182
08/01/12 01:19 AM
08/01/12 01:19 AM
Posts: 150 Illinois
fishy68
Illinois
Moparforlife nailed it. You said you measured 3.906". That's .004" smaller than the minimum. That right there should tell you it's not accurate. The biggest problem is probably the caliper. I have 3 and none read the same. Their all within 2-3 thousandths which is ok for most things but not all.
68 Cuda 408/904/8-3/4 02 Dakota 4.7 auto
[Re: fishy68]
#1277183
08/01/12 04:16 AM
08/01/12 04:16 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have a full set of telescoping gauges I use. I have digital calipers and outside mikes up to 5 inches. The mikes are dead accurate as I check them and calibrate them all the time. The digital caliper is very accurate as I can also calibrate it. The thing is you need a good touch with telescoping gauges to be very accurate. I like to use them for general readings but use my bore gauge for very accurate readings. Ron
[Re: 383man]
#1277184
08/01/12 08:41 AM
08/01/12 08:41 AM
Posts: 738 Columbus Ohio
mopfried
Columbus Ohio
I agree 100%.. Mikes and a good feel for the telescope gauge. Dial bore gauges are dead on.
[Re: dogdays]
#1277187
08/02/12 12:31 AM
08/02/12 12:31 AM
383man
Balt. Md
Unless your snap gauges have rounded ends you will be measuring slightly under the bore size. Like this: (!---!)
I really don't like snap gauges and after using a good bore gauge I am spoiled.
R.
Mine do have rounded ends on all of them. Ron
[Re: 383man]
#1277188
08/02/12 09:01 AM
08/02/12 09:01 AM
Posts: 416 Franklin Co. Illinois
runinonmt
go to your local parts store that rents tools,get the right size Mic,for the standard if nothing else. Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: runinonmt]
#1277189
08/02/12 09:33 AM
08/02/12 09:33 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Snap gauges work fine, but it's one of those things that work fine if you have a lots of practice using them. A bore gauge is more user friendly, especially for someone who doesn't do it often enough.
