Re: How do you burp a radiator?
[Re: Skid_Demon]
#1277163
07/31/12 05:14 PM
07/31/12 05:14 PM
Posts: 487 Sonoran desert, Arizona, USA
moparjo68
After I change a thermostat, I fill rad. back up to full level. Run it 'till it reached operating temp. Shut it off to cool back down. Remove rad. cap, add coolant if needed and put coolant in puke tank if applicable. I know some systems that I have owned require burping such as GM. If your system has a bleeder valve in line, then open bleeder valve while running. You will hear air hissing and then coolant should start spewing out. At that point shut off valve. You've purged the air from the system.
[Re: Skid_Demon]
#1277164
07/31/12 05:14 PM
07/31/12 05:14 PM
RapidRobert
easiest is to drill a 1/32" hole in the flat of the stat just outside the center "mechanism" before installation. lets the air come thru so it will fill completely & does not affect cooling & only takes 1 minute to do. On a tough case with air pockets in the eng cooling passages, jack up the front of the car as high as you can & gun it several times with it warm (stat open)
[Re: RapidRobert]
#1277165
07/31/12 06:18 PM
07/31/12 06:18 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
and as you are filling, squeeze the upper hose like the docs squeeze a bulb to help people breathe. It will work some of those sticky bubbles loose. Many newer cars have special procedures too. Mid-engine cars often require jacking and bleeders. Toyota V6s require filling the heater hose, many FWD cars have bleeders too.
[Re: RapidRobert]
#1277166
07/31/12 06:55 PM
07/31/12 06:55 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
The above is good advise and works every time. Ask me how I know.
[Re: ev2mopar]
#1277169
08/01/12 12:22 AM
08/01/12 12:22 AM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
When I do a fill on a smallblock I pull the heater hose off the intake and fill it till it pushes water out. Done this for some time and it works great with no problems.
Also did the hole in the thermostat thing as well.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
