How do you burp a radiator? #1277161
07/31/12 04:35 PM
07/31/12 04:35 PM
MN
Skid_Demon Offline OP
MN
It's a small block v8. The cap is the highest point in the system. There is a small overflow tank, 15 pound cap. What is the correct way to burp the system after changing the stat?
Re: How do you burp a radiator? [Re: Skid_Demon] #1277162
07/31/12 05:07 PM
07/31/12 05:07 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Well, a coolant recovery system will burp itself. Just make sure to fill the rad full first.
Now if you have a vent cap (the caps with the vent lever) you just flip the vent while its arm/hot and you will speed up the process.
You can then let it cool, come back when its cold and make sure the rad is full and there is still coolant in the recovery tank.
Re: How do you burp a radiator? [Re: Skid_Demon] #1277163
07/31/12 05:14 PM
07/31/12 05:14 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
After I change a thermostat, I fill rad. back up to full level. Run it 'till it reached operating temp. Shut it off to cool back down. Remove rad. cap, add coolant if needed and put coolant in puke tank if applicable. I know some systems that I have owned require burping such as GM. If your system has a bleeder valve in line, then open bleeder valve while running. You will hear air hissing and then coolant should start spewing out. At that point shut off valve. You've purged the air from the system.
Re: How do you burp a radiator? [Re: Skid_Demon] #1277164
07/31/12 05:14 PM
07/31/12 05:14 PM
easiest is to drill a 1/32" hole in the flat of the stat just outside the center "mechanism" before installation. lets the air come thru so it will fill completely & does not affect cooling & only takes 1 minute to do. On a tough case with air pockets in the eng cooling passages, jack up the front of the car as high as you can & gun it several times with it warm (stat open)
Re: How do you burp a radiator? [Re: RapidRobert] #1277165
07/31/12 06:18 PM
07/31/12 06:18 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
and as you are filling, squeeze the upper hose like the docs squeeze a bulb to help people breathe. It will work some of those sticky bubbles loose.
Many newer cars have special procedures too. Mid-engine cars often require jacking and bleeders.
Toyota V6s require filling the heater hose, many FWD cars have bleeders too.
Re: How do you burp a radiator? [Re: RapidRobert] #1277166
07/31/12 06:55 PM
07/31/12 06:55 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
The above is good advise and works every time. Ask me how I know.
Re: How do you burp a radiator? [Re: Hemi ragtop] #1277167
07/31/12 09:51 PM
07/31/12 09:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
over the left shoulder, gently rub in a circular motion and pat firmly. i gotta come up with a new one, i use this everytime the question comes up.
Re: How do you burp a radiator? [Re: mikemee1331] #1277168
07/31/12 10:04 PM
07/31/12 10:04 PM
Woodbridge NJ
E
ev2mopar Offline
ev2mopar  Offline
E
Woodbridge NJ
Drilling a small hole in the thermostat works great.
You can also try using an aspirin, placed between the disc and the framework of the thermostat, install it and use your normal fill procedure..
The aspirin tablet will disolve rather within an hour or so, long enough to "Burp" out any air pockets.
Re: How do you burp a radiator? [Re: ev2mopar] #1277169
08/01/12 12:22 AM
08/01/12 12:22 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
When I do a fill on a smallblock I pull the heater hose off the intake and fill it till it pushes water out. Done this for some time and it works great with no problems.
Also did the hole in the thermostat thing as well.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: How do you burp a radiator? [Re: Skid_Demon] #1277170
08/01/12 02:12 AM
08/01/12 02:12 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Too late now, but you can fill eng through thermo opening with coolant until it is right at the mounting surface, then install thermo, install hose, top off rad and you're good.
