'72 Charger 340 - Leece Neville or 60 amp alternator? #1277144
07/31/12 03:04 PM
07/31/12 03:04 PM
Two Harbors, MN
chrgr340 Offline OP
chrgr340  Offline OP
Two Harbors, MN
I'm in the process of putting my '72 Charger back together and I need some new belts for it. All the car part sites are asking me if it has the Leece-Neville or the 60 amp alternator.
How do I know which of these alternators my car has?
Are there any visible differences?
1972 Dodge Charger - F7, Rallye pkg, 340, A833
2007 Dodge Charger R/T R&T - 12sec daily beater
1999 Dodge Dakota R/T - M1, cam, heads, T56 swap
1997 Dodge Dakota - 318, NV3500, 3.92 Sure Grip
Re: '72 Charger 340 - Leece Neville or 60 amp alternator? [Re: chrgr340] #1277145
07/31/12 04:00 PM
07/31/12 04:00 PM
The LN is the huge 100 amper with the fan behind the pulley and special brackets. Not sure if a small block ever came with the LN bracketry. there was a mention of this in a thread a day or 2 ago. Highly likely that you just have the regular alt EDIT If your alt does NOT have fan cooling vanes behind the pulley then you do not have a LN
Re: '72 Charger 340 - Leece Neville or 60 amp alternator? [Re: RapidRobert] #1277146
07/31/12 08:56 PM
07/31/12 08:56 PM
Two Harbors, MN
chrgr340 Offline OP
chrgr340  Offline OP
Two Harbors, MN
Excellent. I figured it had to be something obvious to identify the difference. Thanks for the info.
Re: '72 Charger 340 - Leece Neville or 60 amp alternator? [Re: chrgr340] #1277147
07/31/12 10:22 PM
07/31/12 10:22 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Not many 72 Charger cop cars.... parts guy must be a Honda enthusiast.
Kevin
