MSD 6AL wiring #1275527
07/29/12 12:03 AM
07/29/12 12:03 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Putting together the MSD 6AL system on my friend '71 Challenger R/T. Curious, all the wires seem to be rather obvious for me, except the red wire that apparently, according to the wiring diagram supplied, goes to the original coil + wire. Would that be the 12V feed on the ballast resistor? It seems on the 6-series modules, the white wire isn't used. Also, apparently you can order the harness PN 8860...
Thanks..
Troy
Troy
Houston Mopar Connection Club
Re: MSD 6AL wiring [Re: hemi68charger] #1275528
07/29/12 12:09 AM
07/29/12 12:09 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the red wire you're referring to is the "key on" +12 volts also called ignition sense so it can be powered by any circuit that comes on with the key and stays on while cranking the engine. yes it can be connected to the ballast resistor feed. the white wire is used when triggering the ignition with a points type distributor. the orange and black pair is coil positive and negative respectively. violet is mag +, green is mag -
Re: MSD 6AL wiring [Re: jamesc] #1275529
07/29/12 01:55 AM
07/29/12 01:55 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
just remember that one side of the ballast resistor is Run..and the one is STart....the red MSD wire must see 12 volts at Start and Run...
usually have to splice the twice ballast resistor wires together then connect the red wire to them...
Tony
70 AARCuda Vitamin C
Re: MSD 6AL wiring [Re: 70AARcuda] #1275530
07/29/12 12:55 PM
07/29/12 12:55 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Typically the ballast res is deep sixed when you install a MSD -- it's no longer necessary. You already have your answers on the red wire -- the white wire is used for a kill switch. White wire to a switch, other side of switch to ground. Grounding the white wire renders the MSD inop.
Re: MSD 6AL wiring [Re: Hotwheelsjr] #1275531
09/08/12 04:13 PM
09/08/12 04:13 PM
Houston, Tx
Houston, Tx
Hello All,,,
I'm still sort of confused on where to connect the white wire to. The red I'm good with, the ballast resistor ( I have hard-wired the ballast in the back to give the engine compartment a more OEM look). The orange and black wires to the coil posts. The heavy gauge red to the battery +, but I'll connect it to the hot post on the starter relay switch and then the black heave gauge wire to a ground. Finally, the distributor harness is obvious..
Thanks..
Troy
Re: MSD 6AL wiring [Re: hemi68charger] #1275532
09/08/12 05:10 PM
09/08/12 05:10 PM
I never used the white wire.
Re: MSD 6AL wiring #1275533
09/09/12 10:41 AM
09/09/12 10:41 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
when i hook up the "keyed" power red wire i attach it to the brown AND blue wire leading to the ballast. i am not sure which color wire is which. but one wire has power and cuts out when you turn the switch to crank. the other wire has no power when the key is on and has power when you turn the switch to start.
you can just attach the red keyed power wire to the old positive side of the coil wire. but you have to use the ballast if you wire it that way.
perception is 90% of reality
Re: MSD 6AL wiring #1275534
09/09/12 11:21 AM
09/09/12 11:21 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
me neither,just nix the br and hook the small red wire to a switched soure.
Re: MSD 6AL wiring [Re: hemi68charger] #1275535
09/09/12 12:59 PM
09/09/12 12:59 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
MSD requires the + and - to be wired directly to the battery for a reason. If you want to have grief with an MSD system, the fastest way to do so is to deviate from the instructions. I've seen them wired to a "more convenient" 12V source before and would not fire. Hooked it to the battery per instructions and Vroooom.
Kevin
Re: MSD 6AL wiring [Re: hemi68charger] #1275536
09/09/12 01:11 PM
09/09/12 01:11 PM
Kirkland, Washington
Pacnorthcuda Offline
As stated, you don't have to use the white wire-----BUT it makes for a great security witch. Just wire it to a hidden switch that is connected to ground.
We you flip the switch the ignition is inop.
I did that on my Cuda
