Odd Ring Gear Question #1275514
07/28/12 11:26 PM
07/28/12 11:26 PM
Oklahoma City
Jwilli500 Offline OP
Oklahoma City
Is the ring gear on a 727 torque converter the same diameter as the ring gear on a manual trans flywheel?
Re: Odd Ring Gear Question [Re: Jwilli500] #1275515
07/28/12 11:38 PM
07/28/12 11:38 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Shouldn't be because there are two multiple flywheel sizes that are matched to a bell housing size.
The torque converters should share the same diameter though.
Re: Odd Ring Gear Question [Re: moparpollack] #1275516
07/28/12 11:49 PM
07/28/12 11:49 PM
Oklahoma City
Oklahoma City
Ooops! I guess I should have specified a 130 tooth, 10.5 clutch version of the manual trans flywheel! Thanks John.
Re: Odd Ring Gear Question [Re: Jwilli500] #1275517
07/29/12 01:58 AM
07/29/12 01:58 AM
Count the teeth on your converter ring gear
Re: Odd Ring Gear Question [Re: Cab_Burge] #1275518
07/29/12 03:28 PM
07/29/12 03:28 PM
Oklahoma City
Oklahoma City
Thanks guys! The reason I'm asking about this is that I am thinking of building an engine run stand. I can get(read I have) an empty auto case a lot cheaper than a manual bell housing. If the flywheel would work in it, that would make things easier, and cheaper. Just thinking out loud a bit...
Re: Odd Ring Gear Question [Re: Jwilli500] #1275519
07/29/12 06:05 PM
07/29/12 06:05 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You aren't the first to think like that. The questioned was posed to me by someone wanting to do the same thing , I haven't looked into it though.
Re: Odd Ring Gear Question [Re: Jwilli500] #1275520
07/29/12 06:19 PM
07/29/12 06:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
727's have a 130-tooth ring gear.
Re: Odd Ring Gear Question [Re: John_Kunkel] #1275521
07/29/12 07:25 PM
07/29/12 07:25 PM
John, We need to help and teach people to think, not give them the answer
Re: Odd Ring Gear Question [Re: Cab_Burge] #1275522
07/29/12 07:54 PM
07/29/12 07:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ten fingers, ten toes...does not equate.
Re: Odd Ring Gear Question [Re: Cab_Burge] #1275523
07/29/12 10:42 PM
07/29/12 10:42 PM
Oklahoma City
Oklahoma City
Dang Cab! Here I was going to try a different approach and just measure the diameter of a torque coverter out in my shop and compare it to the diameter of the flywheel listed on 440 Source! It's a little warm here this weekend for me to get out on my walker. I just thought maybe someone knew the answer off the top of their head. Thanks for teaching me how to fish.
Re: Odd Ring Gear Question [Re: John_Kunkel] #1275524
07/29/12 10:45 PM
07/29/12 10:45 PM
Oklahoma City
Oklahoma City
Thank You John!
