Re: question which year is the best for a street/strip 440
[Re: slowpoke68]
#1275170
07/28/12 01:10 AM
07/28/12 01:10 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Really there isn`t a "bad" year. Most prefer the 68`--71`s . But I`ve used 66`s and 76`s they all did just fine. Its more important that the block check`s out OK for core shift and cracks etc...
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1275171
07/28/12 01:28 AM
07/28/12 01:28 AM
A lot of guys prefer using a 400 block for strokers
[Re: Twostick]
#1275174
07/28/12 08:58 AM
07/28/12 08:58 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Any 400 block that passes a sonic check has a better life expectancy at higher Hp than a 440 block. About the best stroker combo to work with is a 512 cube motor with 4.25 stroke and 4.375 bore. That is a practical limit in the 400 block. Guys have built them bigger, but For a good long life shortblock the 512 is hard to beat. It will also handle up to 850 hp with 440-1 heads, and more with B1 heads. If you plan on SERIOUS power (850 or more) a center counter weighted crank will help take a lot of stress out of the bottom end and extend the life of the motor.
