Best B or RB dual quad intake?
#1275112
07/27/12 09:56 PM
07/27/12 09:56 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Whats the best B or RB dual quad inline intake, that still looks kinda stock( no tunnel rams or crazy box intakes) I'm asking because:
I'd like to put together a F.A.S.T. Like car. Not adhering to the rules to race, but something that looks close to a factory engine.
Here's my idea. Since '58 was the first year for the big block, i'd like to build a 500ish inch stroker. Stealth heads or really good ported irons. Cam will be spec'd by the head ported to match the combo. I'll use HP manifolds, that will have porting/extrude honing. The holdback is the induction system. The 350 golden commando was dual quad only in '58, so i need a good intake. I'll grind off markings and paint tom match the engine. This engine was an option in any plymouth in '58 from the low line four door plaza, to a station wagon, and Fury. So what's a really good intake to use? It doesn't have to be a low profile look, it can be raised like a performer rpm style. As long as once painted with the engine it passes for "close" That'll do. Most likely will be using a 2 door sedan, for weight savings and rigidity.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Best B or RB dual quad intake?
[Re: Spaceman Spiff]
#1275114
07/27/12 11:10 PM
07/27/12 11:10 PM
Posts: 31,050 Oregon
AndyF
I have a tech article on my website with some CH-28 test results. That intake worked pretty well on a 505 inch stroker. www.arengineering.com then click on the tech articles section
#1275118
07/28/12 10:26 AM
07/28/12 10:26 AM
Posts: 4,209 New York
polyspheric
New York
No direct experience, but Vizard has tested some 2×4 dual-planes on SBC and reported very significant differences in flow rates between cylinders. Has anyone tested the CH28?
Boffin Emeritus
[Re: polyspheric]
#1275119
07/28/12 10:39 AM
07/28/12 10:39 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Some may recall...............
Don Dulmage, a freelance writer for Chrysler Power (anyone remember that? Good reading.) ran a 73-74 440 Charger bracket car back in the early 90's or so with a CH-28. He wrote some good things about it, can't remember specifics but I would like to try one some day.
#1275120
07/28/12 12:28 PM
07/28/12 12:28 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
My Jensen Interceptor runs a 440 with a CH28 and two Edelbrock 500 carbs. Runs flawlessly, pulls HARD top end, great low end torque, and it even gets good gas mileage. NO drawbacks IMO. My Charger also has a CH28 intake, but it has two Edelbrock 600s on it, it also runs great, but I haven't finished tweaking it as it has an "off spot" from time to time, slight hesitation when pounding it from a very low rpm. It's close to being 100%, but not quite yet... I have just bought another CH28 intake, and two more Edelbrock 500 carbs. I have a warmed over 440 with a decent cam and headers, and will convert to dual quads in the fall. It's for my...... motorhome.
CrAzYMoPaRGuY
[Re: polyspheric]
#1275121
07/28/12 12:45 PM
07/28/12 12:45 PM
AndyF
No doubt the flow rate between cylinders is significant. But when we did the dyno tests on the 505 engine the CH-28 worked really well. Idle quality was fantastic. Torque curve looked good, EGT's in all 8 cylinders looked normal, plugs looked good, etc.
My recommendation would be to just run it a little rich to be safe. Unless you put an O2 sensor in each header pipe you won't know for sure. Even then, you would probably have trouble fixing the issue.
