Eddy Carb Suggestions
#1275093
07/27/12 09:36 PM
07/27/12 09:36 PM
Posts: 581 Detroit, MI
David Hakim
super street
super street
Detroit, MI
Okay, Moparts, I'm on the fence picking a carb for the wife's '68 New Yorker. Here's the details Fresh 440 .030 over 9.0:1 compression Comp Cams XE250 - http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=704&sb=0 Stock Intake Manifold HP exhaust manifold w/duals MPP Electronic Ignition 2.76 axle ratio 727 w/12 convertor Would you bolt on an Edelbrock 600 or 750 performer? This is 4000+lbs. cruiser/road trip machine Thanks.
Re: Eddy Carb Suggestions
[Re: DaytonaTurbo]
#1275099
07/28/12 01:25 AM
07/28/12 01:25 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
Have you ever seen this demon carb its a 625 cfm anlooks more period Correct. web page
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#1275100
07/28/12 01:58 AM
07/28/12 01:58 AM
Posts: 10,220 Someplace you aren't
SomeCarGuy
Best mileage cruiser I had was a 383 with a 600 Eddy. Don't even consider the 750 Eddy for any reason. That new TQ ripoff looks like an interesting rig.
I want my fair share
[Re: SomeCarGuy]
#1275101
07/28/12 03:05 AM
07/28/12 03:05 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, period correct, but not the correct period, 1971 was the first year for a production correct Mopar TQ application.
For a 68 C-body 440 car (Non HP) a 4160 series Holley carb would have been installed from the factory. 68 HP 440 cars would have had an AVS. Both the factory AVS and the Holley flowed around 600 CFMs so a similar sized modern replacement would work fine on the described build.
If you want to go outside the "original" box a bit further an intake swap to a spread bore design (early 70's iron spread bore 440 intakes are cheap, common, and flow pretty decent) and a properly built Thermo-Quad would likely yield the best overall power and economy.
