Eddy Carb Suggestions #1275093
07/27/12 09:36 PM
07/27/12 09:36 PM
Detroit, MI
David Hakim Offline OP
super street
super street
Detroit, MI
Okay, Moparts, I'm on the fence picking a carb for the wife's '68 New Yorker.
Here's the details
• Fresh 440 .030 over
• 9.0:1 compression
• Comp Cams XE250 - http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=704&sb=0
• Stock Intake Manifold
• HP exhaust manifold w/duals
• MPP Electronic Ignition
• 2.76 axle ratio
• 727 w/12” convertor
Would you bolt on an Edelbrock 600 or 750 performer?
This is 4000+lbs. cruiser/road trip machine
Thanks.
Re: Eddy Carb Suggestions [Re: David Hakim] #1275094
07/27/12 09:38 PM
07/27/12 09:38 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
How about a 60's vintage rebuilt AVS? If EB is the only choice I'd reccomend the 600 for that car.
Re: Eddy Carb Suggestions [Re: ScottSmith_Harms] #1275095
07/28/12 12:14 AM
07/28/12 12:14 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id be putting a Holley on it.
I am truckless..
Re: Eddy Carb Suggestions [Re: 340SHORTY] #1275096
07/28/12 12:22 AM
07/28/12 12:22 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
The 600 will be more than adequate and will probably give decent mileage.
Re: Eddy Carb Suggestions [Re: Lee446] #1275097
07/28/12 12:47 AM
07/28/12 12:47 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
650 thunder series
Re: Eddy Carb Suggestions [Re: ScottSmith_Harms] #1275098
07/28/12 01:01 AM
07/28/12 01:01 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
With that build, IMO you'd be happier with that edelbrock 600 rather than a 750 or any of the holley offerings.
Re: Eddy Carb Suggestions [Re: DaytonaTurbo] #1275099
07/28/12 01:25 AM
07/28/12 01:25 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Have you ever seen this demon carb its a 625 cfm anlooks more period Correct. web page
1969 Dodge Charger 1969 Dodge Superbee
Re: Eddy Carb Suggestions [Re: cjs69mope] #1275100
07/28/12 01:58 AM
07/28/12 01:58 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Best mileage cruiser I had was a 383 with a 600 Eddy. Don't even consider the 750 Eddy for any reason. That new TQ ripoff looks like an interesting rig.
I want my fair share
Re: Eddy Carb Suggestions [Re: SomeCarGuy] #1275101
07/28/12 03:05 AM
07/28/12 03:05 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, period correct, but not the correct period, 1971 was the first year for a production correct Mopar TQ application.
For a 68 C-body 440 car (Non HP) a 4160 series Holley carb would have been installed from the factory. 68 HP 440 cars would have had an AVS. Both the factory AVS and the Holley flowed around 600 CFMs so a similar sized modern replacement would work fine on the described build.
If you want to go outside the "original" box a bit further an intake swap to a spread bore design (early 70's iron spread bore 440 intakes are cheap, common, and flow pretty decent) and a properly built Thermo-Quad would likely yield the best overall power and economy.
Re: Eddy Carb Suggestions [Re: Lee446] #1275102
07/28/12 10:49 AM
07/28/12 10:49 AM
X2 I had one on a 440 in a C body (PO installed) & it ran flawless & plenty of power
Re: Eddy Carb Suggestions [Re: 340SHORTY] #1275103
07/28/12 11:10 AM
07/28/12 11:10 AM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
i'd be putting a holley on it}
excellent answer-so would i.
