How to remove silicone spray from glass/ windows! #1274876
07/27/12 12:08 PM
07/27/12 12:08 PM
chatham, Ilinois
fox Offline OP
super street
fox  Offline OP
super street
chatham, Ilinois
Anyone know how to clean silicone off of glass? I just bought a different truck and the seller/idiot sprayed the drivers windon with silicone for some odd reaason. I've tried windex, rubbing alcohol, gasoline, simply green,and car polish.
What to do?
Re: How to remove silicone spray from glass/ windows! [Re: fox] #1274877
07/27/12 12:19 PM
07/27/12 12:19 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
Use Omni MS-251 spray gun cleaning solvent. You can get it from your PPG auto paint store or other brands may have a similar product ( Spray gun cleaning solvent). It works good for removing RTV, 3M weatherstrip adhesive ( gorilla snot ) and aviation sealer ( Baby poop) from gasket surfaces too.
I should be a salesman for this stuff. Once you use it you will see..... The stuff work on everything.
Re: How to remove silicone spray from glass/ windows! [Re: GreenGlow] #1274878
07/28/12 11:19 PM
07/28/12 11:19 PM
chatham, Ilinois
fox Offline OP
super street
fox  Offline OP
super street
chatham, Ilinois
Ok thanks.
Anyone else find a cleaner for it?
Re: How to remove silicone spray from glass/ windows! [Re: fox] #1274879
07/29/12 07:24 AM
07/29/12 07:24 AM
Morningside, Long Island
scatcity Offline
scatcity  Offline
Try plain vinegar. The acidics may work.
Re: How to remove silicone spray from glass/ windows! [Re: scatcity] #1274880
07/29/12 04:47 PM
07/29/12 04:47 PM
chatham, Ilinois
fox Offline OP
super street
fox  Offline OP
super street
chatham, Ilinois
That didn't work! That stuff is tough to clean up.
If I lived closer to him, I would go silicone all his windows!
Re: How to remove silicone spray from glass/ windows! [Re: fox] #1274881
07/29/12 05:15 PM
07/29/12 05:15 PM
IN
ahy Offline
ahy  Offline
IN
Auto body shops (and Eastwood and Autocolorlibrary.com) sell a special solvent formulated for paint prep that cuts silicone (grease and wax remover). I'd try that.
Re: How to remove silicone spray from glass/ windows! [Re: ahy] #1274882
07/29/12 05:37 PM
07/29/12 05:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Acetone removes just about everything. Available at ACE hardware.
