Re: which Junk yard starter?
[Re: GreenGlow]
#1273645
07/25/12 05:28 PM
07/25/12 05:28 PM
Posts: 15,487 Florida
scratchnfotraction
The starter I put on my 96 Ram window licker/Mormon war wagon van had the 2 studs on it for the power and control wire. The 2 studs will save you a bunch of trouble trying to find a plug to connect the control wire.
I had to clip and splice a plug for the JY mini i got from a 97-98 ram 1500(IIRC) on to my 85 truck.
I get them over the counter for a 92-93 5.2 Dak and remove the extetion piece,hook wire right to 2 studs.
[Re: scratchnfotraction]
#1273646
07/25/12 06:03 PM
07/25/12 06:03 PM
Challenger 1
Cincinnati, Ohio
I think the last time I asked for 90 dakota and the they said it used the same starter V6 or V8?
[Re: Challenger 1]
#1273647
07/25/12 06:26 PM
07/25/12 06:26 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Any RWD V6/V8 mini starter will work.. As said on 1 of them the starter relay wire is a plug in, not a bolt on....
I am truckless..
