which Junk yard starter? #1273640
07/25/12 02:15 PM
07/25/12 02:15 PM
Chilliwack, BC, Canada
Y
Y2RR Offline OP
Y2RR  Offline OP
Y
My search function is not working properly and I know this has been talked about numerous times, but which mini type starter either from Dakota or Ram will fit a 318? Thanks
Re: which Junk yard starter? [Re: Y2RR] #1273641
07/25/12 02:25 PM
07/25/12 02:25 PM
U.P. ,MI.
P
plumcuda Offline
plumcuda  Offline
P
U.P. ,MI.
They're the same starter.I asked the parts guy for a starter for a 1996 Dodge Ram 360.
Re: which Junk yard starter? [Re: Y2RR] #1273642
07/25/12 02:25 PM
07/25/12 02:25 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
dodge caravan works ,I have one on my 500 stkr.
Re: which Junk yard starter? [Re: moparsquid] #1273643
07/25/12 03:53 PM
07/25/12 03:53 PM
Y
Y2RR Offline OP
Y2RR  Offline OP
Y
Thanks for the input and I will pass it on to my buddy who needed to know in order to replace the old starter in his 69 Barracuda convt.
Re: which Junk yard starter? [Re: Y2RR] #1273644
07/25/12 05:19 PM
07/25/12 05:19 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
The starter I put on my 96 Ram window licker/Mormon war wagon van had the 2 studs on it for the power and control wire. The 2 studs will save you a bunch of trouble trying to find a plug to connect the control wire.
Re: which Junk yard starter? [Re: GreenGlow] #1273645
07/25/12 05:28 PM
07/25/12 05:28 PM
scratchnfotraction Offline
I had to clip and splice a plug for the JY mini i got from a 97-98 ram 1500(IIRC) on to my 85 truck.
I get them over the counter for a 92-93 5.2 Dak and remove the extetion piece,hook wire right to 2 studs.
Re: which Junk yard starter? [Re: scratchnfotraction] #1273646
07/25/12 06:03 PM
07/25/12 06:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think the last time I asked for 90 dakota and the they said it used the same starter V6 or V8?
Re: which Junk yard starter? [Re: Challenger 1] #1273647
07/25/12 06:26 PM
07/25/12 06:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Any RWD V6/V8 mini starter will work.. As said on 1 of them the starter relay wire is a plug in, not a bolt on....
I am truckless..
Re: which Junk yard starter? [Re: 340SHORTY] #1273648
07/25/12 09:40 PM
07/25/12 09:40 PM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
I used one off a 95 Ram (or at least that is what I asked for at the JY, and what they pulled off the shelf) and it works perfect.
The only thing I had to do was bend the tab on the end of the batery cable a bit.
Jason
