Page 1 of 4 1 2 3 4
Check out this video...tire separating from the wheel #1272441
07/23/12 04:03 AM
07/23/12 04:03 AM
Heaven
EvilB1Dart Offline OP
Heaven
http://www.youtube.com/watch?v=p2rnGg6Tnfg&feature=youtube_gdata
Notice how the tire is separating from the inner side of the rim lip during the burnout and the pass with video on the wheel. Another reason why I like beadlocked wheels on a fast car. These wheels have a ton of rim screws, but that's kinda scary. Wide wheel with little tire;commonly used.
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272442
07/23/12 06:37 AM
07/23/12 06:37 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
That is kinda scary! I think that realistically, that car needs bead locks, I don't think I have ever seen a rear wheel with that many rim screws!
Alan Jones
Re: Check out this video...tire separating from the wheel [Re: LA360] #1272443
07/23/12 06:49 AM
07/23/12 06:49 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Another DR guy that would have been DQ'd at our track before he staged....Can't go past the line doing a burnout with a door car.
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272444
07/23/12 10:11 AM
07/23/12 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm wondering if its just a radial thing... but you
could see that it pulled in to the screws(and he sure
has enough of them... if I had to put that many in I
would have gone to bead locks)
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272445
07/23/12 10:18 AM
07/23/12 10:18 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've seen video of Pro Stock cars from years ago that would seperate the tire from the wheel.
Wes, do you know what tire/wheel combination he's running? looks like a 275 on a 12" wheel. Whatever it is the tire looks really small for the wheel.
Re: Check out this video...tire separating from the wheel [Re: LA360] #1272446
07/23/12 10:37 AM
07/23/12 10:37 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
He is running a slick. It is not a drag radial.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Check out this video...tire separating from the wheel [Re: Dragula] #1272447
07/23/12 10:39 AM
07/23/12 10:39 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So a outlaw 10.5 car can't go past the starting line on the burnout at your track? Wow I guess you don't run any of them there.
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272448
07/23/12 10:54 AM
07/23/12 10:54 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
the wheel is to wide for the tire...
the tread should be equal or a bit wider that the rim width...tires grow with speed and having tall series sidewalls...there's a reason for bead locks
Re: Check out this video...tire separating from the wheel [Re: 1967dartgt] #1272449
07/23/12 01:37 PM
07/23/12 01:37 PM
Dragula Offline
Dragula  Offline
We get a couple of them now and again...Can't say I have seen a whole class of them run. Still not allowed to go past the beams...DQ'd!
Re: Check out this video...tire separating from the wheel [Re: Dragula] #1272450
07/23/12 01:49 PM
07/23/12 01:49 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
For the record; Charlie doesnt run a radial tire, he runs a 28x10.5 stiff side wall slick. He's has many championships with NMCA and NMRA Hotstreet and Pro Stock under his belt with that stang!
Charlie is a good guy!
And by the way, that car now sports a Pro flight trans.
It's a bigblock with a torque flight!!!
Re: Check out this video...tire separating from the wheel [Re: mopar_to_ya] #1272451
07/23/12 02:17 PM
07/23/12 02:17 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I wouldnt call that a separation, it just grew and when a tire grown it narrows lifting the sidwall off the bead edge. If there was an issue with that ET and power level it would have showed its ugly face by now.
Rim could be a tad wide for the tire, but I dont see a huge deal there, kinda neat accually.
Re: Check out this video...tire separating from the wheel [Re: mopar_to_ya] #1272452
07/23/12 03:20 PM
07/23/12 03:20 PM
Dragula Offline
Dragula  Offline
Who's making those? And what is it exactly?
I see Transact has a set of straight cut gears comming out and a conversion to convert a 727 into a two speed trans with different 1st gear ratios available soon according to their website.
Re: Check out this video...tire separating from the wheel [Re: smokinwoody] #1272453
07/23/12 04:43 PM
07/23/12 04:43 PM
Az
Crizila Offline
Crizila  Offline
Az
Yep!!
Fastest 300
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272454
07/23/12 05:57 PM
07/23/12 05:57 PM
Heaven
Heaven
Yeah I know its Charlie's car and what he's done with it. Reason there hasn't been a mishap is because of the amount of screws he runs and the fact that he changes tires like we do underwear. To the average guy who runs pass after pass using up the tire as much as possible, this could be dangerous on a fast car. Its the reason why I posted it.
Its most likely a 12" or 13" wheel with a 28 x 10.5 sitting on it. Thats what most of the NMRA Hot Street and SuperStreet Outlaw boys run on.
Glidden use to run a ton of screws on his wheels a while ago UNTIL a tire came off in testing on the old black car (tire separated itself from the wheel and screws). But that car was always UP N GONE in the 60' like a Pro Stock car.....lol. Beadlocks from then on......
Re: Check out this video...tire separating from the wheel [Re: EvilB1Dart] #1272455
07/23/12 08:51 PM
07/23/12 08:51 PM
Guitar Jones Online laugh2
Yeah, I think if I saw that on my car there would be beadlocks on it the next time out.
Re: Check out this video...tire separating from the wheel [Re: Guitar Jones] #1272456
07/23/12 09:44 PM
07/23/12 09:44 PM
Az
Crizila Offline
Crizila  Offline
Az
How about just getting the right size wheels for the tires. There is an accident waiting to happen - not to mention not getting good use of the tire foot print.
Fastest 300
Re: Check out this video...tire separating from the wheel [Re: Crizila] #1272457
07/23/12 09:50 PM
07/23/12 09:50 PM
A lot of racers, especially the small tire guys are using wider wheels by an inch or so of the tread width. I think the reasoning is that they can run more air pressure and keep a flatter footprint, at least that's what I heard.
Re: Check out this video...tire separating from the wheel [Re: Crizila] #1272458
07/23/12 09:56 PM
07/23/12 09:56 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Here is my friends car. He has a big tire on the car but is still peels back from the bead at high speed. Bead locks are required for cars 200 mph or faster.
Screws will hold just fine.
http://youtu.be/Mq74hLBlZxA
Re: Check out this video...tire separating from the wheel [Re: Guitar Jones] #1272459
07/23/12 10:13 PM
07/23/12 10:13 PM
Az
Crizila Offline
Crizila  Offline
Az
I wouldn't drive it. I would just about guarantee that combo is outside the tire manufacturers rim size recommendation - and there sure as hell is more than 1" difference. Rim screws were never ment to be utilized as bead locks. Glad I don't race at his track.
Fastest 300
Re: Check out this video...tire separating from the wheel [Re: Crizila] #1272460
07/23/12 10:44 PM
07/23/12 10:44 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Don't most of the fast stockers run a 12" wheel with a 9" tire? Gives a wider foot print I think. Not going 150 mph though.
Brian Dunnigan
Page 1 of 4 1 2 3 4
