Dry hops ? #1271792
07/22/12 03:30 AM
07/22/12 03:30 AM
E
EJ440 Offline OP
EJ440  Offline OP
E
Why did we stop ?
Re: Dry hops ? [Re: EJ440] #1271793
07/22/12 03:46 AM
07/22/12 03:46 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
dry hops came after the real burnout. it was proven to be more harm than good
The 1st hit of the throttle is when the tires will hook the best, so if you dry hop you just took that 1st hit & wasted it instead of using it to launch your car.
home of the
Sox and Martin Hemi Duster
Re: Dry hops ? [Re: HEMIFRED] #1271794
07/22/12 08:38 AM
07/22/12 08:38 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I agree 100%
Plus why take the chance in tearing something up for nothing.
Leon
Re: Dry hops ? [Re: Leon441] #1271795
07/22/12 11:43 AM
07/22/12 11:43 AM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Tire technology, track prep, clutch technology all changed the before staging procedures.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Dry hops ? [Re: Slingshot383] #1271796
07/22/12 11:47 AM
07/22/12 11:47 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
They sure were fun.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dry hops ? [Re: pittsburghracer] #1271797
07/22/12 12:08 PM
07/22/12 12:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Some of us still do them at the stick shift races because the fans love them,and isn't that what we do this for
64 Plymouth Savoy
Dana 60
Re: Dry hops ? [Re: EJ440] #1271798
07/22/12 12:13 PM
07/22/12 12:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you talk to any tire manufacturer they will tell
you that after the burn out to move to the line as quick
as possible... as said already... why take the chance
of breaking something for nothing... I've seen people
do 2 or 3 dry hops and in some cases they never made
it to the line due to breakage (plus I always thought
it was just DUMB)... the burnout is for 2 reasons...
clean the tire and put heat in it and the longer you
hang around the heat dissipates
Re: Dry hops ? [Re: MR_P_BODY] #1271799
07/22/12 12:51 PM
07/22/12 12:51 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
By doing dry hops you are using up all the sticky you just put into the tire plus you put in a ton of heat into the sidewalls.
JAKES AUTOMOTIVE
Re: Dry hops ? [Re: JAKE68] #1271800
07/22/12 01:02 PM
07/22/12 01:02 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
as well as producing a lot of heat into the converter and trans fluid.
Re: Dry hops ? [Re: Red440] #1271801
07/22/12 01:13 PM
07/22/12 01:13 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I remember when I used to do dry hops with my old race car high 11,low 12 sec car. Then got my 64 ply and came out of the water did a dry hop and stood it up and came down not knowing I smashed the pan and locked up the motor next run. No more dry hops.
JAKES AUTOMOTIVE
Re: Dry hops ? [Re: JAKE68] #1271802
07/22/12 02:12 PM
07/22/12 02:12 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
John Hazzelrig was the king of the dry hops at Motion with his '69 Roadrunner. He'd do a huge burnout, then do 4 dry hops, and clear the motor out twice after each one.
First guy I remember not doing a dry hop was Fred Catlin with his C/SA buick back in the mid '80's. He'd do a good burnout and roll up to the stage light without ever clearing the motor out or anything. He'd bump it in and it would almost drag the back bumper when it left.
Never did another dry hop after that.
Re: Dry hops ? [Re: slantzilla] #1271803
07/22/12 04:53 PM
07/22/12 04:53 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
I often still do dry hops and I haven't seen an increase in my 60 foots because of it, so I'm skeptical about the theory of "using up the sticky" in the tires after the burnout. Granted, it's hard on parts and doesn't improve performance but they are fun to do and the spectators love it.
If I was worried about breaking stuff, I wouldn't be drag racing and I sure wouldn't be driving a stick car.
Re: Dry hops ? [Re: fourgearsavoy] #1271804
07/22/12 05:46 PM
07/22/12 05:46 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
You might do something for the fans enjoyment but def not everyone. I could give 2 $hits about impressing someone. I do this for me. FTW
One day I will have something cool here.
Re: Dry hops ? [Re: mloboda] #1271805
07/22/12 06:00 PM
07/22/12 06:00 PM
Muncie
Racebuddy Offline
Racebuddy  Offline
Muncie
Once in a while I can come out of the burnout box weird and feel like maybe one tire didn't get lit up well. I will bark them once again before staging.
I really like to burn out mildly and get it to the line.
Re: Dry hops ? [Re: Racebuddy] #1271806
07/22/12 07:17 PM
07/22/12 07:17 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
My understanding is that when you do the burn out the heat brings up a substance up from the tire that enhances traction......I heard it described as " oils " , but what ever it is , you scrub it off with the dry hop.
Heat them , stage it and go to work.
Re: Dry hops ? [Re: sdaurity] #1271807
07/22/12 09:03 PM
07/22/12 09:03 PM
Rittman Ohio
Rittman Ohio
Well I race for fun and enjoyment some folks just do it for the money
When you go to a stick-shift race there are actually fans that come to watch "real" real race cars not something that can be controlled with a radio in the stands
Bravo with your "no-hop" stance I hope you win every round
Gus
64 Plymouth Savoy
Dana 60
Re: Dry hops ? [Re: sdaurity] #1271808
07/22/12 10:16 PM
07/22/12 10:16 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Not specifically trying to impress anyone, just bring a smile to the spectators faces. When the spectators smile, I smile.
Re: Dry hops ? [Re: mloboda] #1271809
07/22/12 11:41 PM
07/22/12 11:41 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
Not a dry Hop but a crowd pleaser. The fans realy enjoyed all my dzus fastners riping out of my fiberglass hood last year at the 990' mark. Made every one smile except me.
Re: Dry hops ? [Re: EJ440] #1271810
07/22/12 11:59 PM
07/22/12 11:59 PM
tennessee
mike54 Offline
mike54  Offline
tennessee
stopped?...i thought it was part of drivin a stick car..lol
Re: Dry hops ? [Re: mike54] #1271811
07/23/12 02:12 AM
07/23/12 02:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I started bracket racing back in the late 70's with my 340 four speed Dart it was the normal thing at that time. So I would do just one and I figured it was to see how the tires are hooking and make sure no water is on them from the wheelwells. I did not know any better at that time but when I heard the first launch after heating the tires is the best I started doing like everyone does now with no dry hops.
I gotta admit it was kinda cool to see a car pop a small wheelie and then stage. Ron
