440 "break in" timing question #127152
09/27/08 04:09 PM
09/27/08 04:09 PM
Salem, OR USA
U
uh60lbhawk Offline OP
U
Salem, OR USA
I'm restoring (well, more like building it my way) a 69 charger. It's a cast crank 440. I have the right flex plate to use it with my 727 and unweighted torque convertor.
Also I have a 440 with the correct harmonic balancer now (thanks moparts forum!). I had the crank re-balanced, it was 60 grams off!
Now, what should the timing mark be at when I line up the distributor on #1, prior to the first start, and break-in? I am switching to an MSD 6AL controler during this engine change, will that have any effect on what the timing is set at?
It's sitiing right a tdc now, so moving it a little to the correct mark shouldn't wipe too much cam lube off (I was liberal with the lube ).
Also, any tips on the break-in would be appreciated. I have heard 20 minutes at 20 thousand rpm, I've heard 30 minutes, I've been told to run a special "break in" oil (I think it's a chevy thing though).
It's a mopar performance purple cam 274/274.
I'm open to any help.
Thanks,
Clint
Re: 440 "break in" timing question [Re: uh60lbhawk] #127153
09/27/08 04:22 PM
09/27/08 04:22 PM
Tampa, FL
Saint Crispan Offline
Tampa, FL
20 thousand RPM!?
Re: 440 "break in" timing question [Re: Saint Crispan] #127154
09/27/08 05:06 PM
09/27/08 05:06 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
20 thousand RPM!?
Re: 440 "break in" timing question [Re: 62maxwgn] #127155
09/27/08 05:15 PM
09/27/08 05:15 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
If you are sure you are at TDC, the timing pointer should be at the zero mark on the dampener, or VERY close. Then turn the distributor so that the rotor lines up with number one post on the cap. I just left it there before I fired my 440 for the first time, but was ready with a timing light to quickly put the timing where I wanted it, once the engine fired. I used 18* initial.
2000-2500 rpm for 20-25 minutes should be adequate for a flat tappit cam breakin. What are your cam specs? High spring pressures?
Oh, I just saw what cam you had.
I added GM EOS oil additive for my breakin. I will also be ading it to all oil changes too, I think. Only $8 a bottle.
codfish
Re: 440 "break in" timing question [Re: codfish] #127156
09/27/08 07:37 PM
09/27/08 07:37 PM
remove thermostat set initial at 5 or 10 before. one guy to man the timing light & turn the dist one guy to add trans fluid one guy to check underneath for leaks remove inner springs 20 to 30 minutes at ~2500 use an oil with plenty of zinc, a bottle of gm EOS have idle speed cranked up several accelerator pumps of gas to prime it for FAST startup & READ THIS "the breakin secrets" at www.mototuneusa.com
Re: 440 "break in" timing question [Re: RapidRobert] #127157
09/27/08 11:17 PM
09/27/08 11:17 PM
Salem, OR USA
U
U
Salem, OR USA
Thanks for the info guys.
Yeah, that was a typo, should have read 2 thousand rpm for 20 minutes....
Clint
Re: 440 "break in" timing question [Re: uh60lbhawk] #127158
09/28/08 11:12 AM
09/28/08 11:12 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i usually fire it.. then immediately twist the dist advanced until the engine doesnt climb rpm anymore that way the engine doesnt get hot too quickly [you have all seen glowing pipes from retarded timing] and runs much cleaner dan
