Re: Edelbrock Dp4b intake-how rare are these and where can
[Re: Dan Halen]
#1271469
07/21/12 10:46 AM
07/21/12 10:46 AM
Posts: 4,961 WI
Dcuda69
WI
[Re: 70 Roadrunner*]
#1271471
07/21/12 10:52 AM
07/21/12 10:52 AM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Ebay !!!
They pop up every once in awhile - But look for stripped threads or heli coils on the carb mounting threads , to find a mint one might bee a stretch and then of course cost
I guess i dont understand everyones dedication with these intakes when they only put out at best , maybe and i mean maybe a few more hp then the newer Edelbrock Performer Intake
Of course the Performer RPM is a different animal but hood clearance always comes into play
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
#1271472
07/21/12 10:54 AM
07/21/12 10:54 AM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
I figured they were a bit hard to find so 100$ wouldn't have been to nuts...the hunt is on
If you already have a stock late 60's-early'70's 4bbl. intake, the
DP4B will not make your car faster. I've been there done that 30yrs
ago. ![](/ubbthreads/images/graemlins/Twocents.gif)
#1271473
07/21/12 11:09 AM
07/21/12 11:09 AM
Posts: 15,487 Florida
scratchnfotraction
you might look at an weiand action plus intake. its old skool like the dp4b but a little more performance same hieght as a stocker/dp4b from the looks of it. i run one on my stock 78 440 with a 600 carb, kinda going opposite of you though,i am looking to poke one thru the hood. ![](/ubbthreads/images/graemlins/laugh2.gif) another option might be a old skool holley street/strip dominator,they are a low rise single plane,spredbore intake that works rather well on the street for a single plane intake,IMO.
[Re: tboomer]
#1271476
07/21/12 11:32 AM
07/21/12 11:32 AM
Dan Halen
Harm City Md.
What Scratchy says!! Much better intake!!
Yep! I use the Holley on the 383 I just built for my ride.
![](http://i897.photobucket.com/albums/ac172/streetvandan/van014.jpg)
![](http://i897.photobucket.com/albums/ac172/streetvandan/DSC01853-1.jpg)
[Re: Dan Halen]
#1271477
07/21/12 11:39 AM
07/21/12 11:39 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
This intake won't fit under his N96 hood without cobbling up an expensive air cleaner, so even though its a better intake it's not fitting his criteria. One advantage the DP4B has over the stock iron itake , it's 20lbs lighter.
[Re: dart1962_440]
#1271481
07/21/12 02:37 PM
07/21/12 02:37 PM
JohnRR
I heard the DP4B is taller than a stock 4bbl intake - is this correct? Anyone have the heights of the various intakes being discussed above?
If it's taller it in not by much as I used it on a 383 in my 1969 Superbee with N96 hood and a factory air cleaner assembly that was not modified in anyway, no problems.
[Re: dart1962_440]
#1271483
07/21/12 05:20 PM
07/21/12 05:20 PM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
About 0.4"
![](http://img140.imageshack.us/img140/2046/stockvsdp4b.jpg)
