67 cuda trunk extension?
#1271019
07/20/12 07:14 PM
07/20/12 07:14 PM
Posts: 5,669 South Dakota
hotairballoonpilot
South Dakota
Wondering if anyone knows how close duster or dart extensions are to a 67 cuda? Got a customer that just bought a notch back that needs lower qrt patches and extensions. I can buy AMD qrt patches but Alan at AMD said the early cuda extensions are in the works but have not been test fitted and are at least 4-5 months out. We both were wondering how close they both are as I need just the front probably 6 inches square of both sides. If they are close then we may buy either of them and cut a patch out to fix his rather than make them out of flat stock.
Contact Me about AMD Prices
Re: 67 cuda trunk extension?
[Re: hotairballoonpilot]
#1271020
07/20/12 11:02 PM
07/20/12 11:02 PM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
MP-38L MOPAR A-BODY TRUNK FLOOR EXTENSION Autobody Specialties says that they fit but you have to modify them. http://www.autobodyspecialt.com/cgi-bin/commerce.cgi?search=action&category=0168USA MADE,THIS DIE FORMED PANEL FILLS THE GAP BETWEEN THE SIDE OF THE TRUNK AND AND THE REAR QUARTER.ALSO KNOWN AS A DROP DOWN FITS:70-76 DUSTER, 71-72 DEMON, DEMON, 73-76 DART SPORT 67-69 BARRACUDA MODIFY TO FIT, CALL $82.00 | More Info
JB Rhinehart, Realist
A-Body's RULE!
[Re: markz528]
#1271022
07/21/12 01:03 AM
07/21/12 01:03 AM
hotairballoonpilot
South Dakota
Thanks guys that is what I was wondering/figuring would be the case.
Corey
#1271023
07/23/12 04:18 PM
07/23/12 04:18 PM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Markz is correct. I bought the dart ones. They are the correct length and they are the correct height and that is about it. Modifications that will need to be made include; they are not the correct width so will need to be sectioned and rewelded, the rearend of a barracuda is narrower and more tapered than a dart so this must be addresssed, and a dart has a different wheelwell design so the dart extensions are missing some metal(3-4") right up by the wheel well. The last part is not as big a deal as one might first think as all you need to do is go to your local ACE hardware store and buy some sheet metal, put a couple of bends in it and weld it up. It isn't going to be OEM, but it will do unless you are going for OEM Gold standards. In other words, the dart extensions are a good place to start, but a knowledge of bodywork is a good thing to get the desired results.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
