Favorite Carb/Parts Cleaner? #1270008
07/18/12 03:26 PM
07/18/12 03:26 PM
dogdays Offline OP
dogdays  Offline OP
I've got a stack of dirty carbs that are about worthless if I don't clean them up. My last 5-gallon bucket of carb cleaner, you remember the stinky stuff that burned when it touched your skin, is about used up. Plus it contains at least two different known carcinogens.
Looking around I find three: Berryman, Gunk, and CRC parts c;leaner fluid. Any suggestions or favorites?
Thanks,
R.
Re: Favorite Carb/Parts Cleaner? [Re: dogdays] #1270009
07/18/12 03:39 PM
07/18/12 03:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I like this stuff, same as the old stuff. Sealed in with water on top.
Nasty as hell but have never found anything better.
I have reused this stuff about 8 times so far, I did my carb wth it last fall. 50 bucks a gallon from the auto paint store. You will never find it at the hardware store I don't think.
Re: Favorite Carb/Parts Cleaner? [Re: dogdays] #1270010
07/18/12 04:30 PM
07/18/12 04:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Even though it's not as potent as it used to be, I think the Berrymans Parts Dip is the best for carbs, etc.
Re: Favorite Carb/Parts Cleaner? [Re: John_Kunkel] #1270011
07/18/12 04:33 PM
07/18/12 04:33 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
For some kinds of gunk, I find brake cleaner works a ton better than parts cleaner. I try a blast of both and sometimes some cheapo no-name brake cleaner blasts away stuff I'd have to scrub off with a dip or carb spray.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Favorite Carb/Parts Cleaner? [Re: Secret Chimp] #1270012
07/18/12 05:14 PM
07/18/12 05:14 PM
dogdays Offline OP
dogdays  Offline OP
If I started buying spray cans I'd most likely spend more than the $100 or so for the big bucket.
R.
Re: Favorite Carb/Parts Cleaner? [Re: dogdays] #1270013
07/18/12 08:22 PM
07/18/12 08:22 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: Favorite Carb/Parts Cleaner? [Re: Ply72rr] #1270014
07/19/12 01:26 AM
07/19/12 01:26 AM
New State
kidmopar Offline
kidmopar  Offline
New State
Re: Favorite Carb/Parts Cleaner? [Re: kidmopar] #1270015
07/19/12 02:35 AM
07/19/12 02:35 AM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
For years I have used and re-used the Gunk brand carb cleaner. I think it retails now for $20 bucks for about a gal. I like the results or wouldn't keep using it.
Re: Favorite Carb/Parts Cleaner? [Re: moparjo68] #1270016
07/19/12 03:51 AM
07/19/12 03:51 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Its 17.00 per gallon for the refils for the 5 gallon bucket of the Berrymans B-12. so around 60.00 for 3 gallons, which should be enough for your bucket with the basket. tim
Re: Favorite Carb/Parts Cleaner? [Re: astjp2] #1270017
07/19/12 04:26 AM
07/19/12 04:26 AM
beedees Offline
beedees  Offline
I use a cleaner called Awesome, get it at the Dollar Store. At $2.00 a quart, it can't be beat and works great. Won't burn your skin or stink the place up.
Re: Favorite Carb/Parts Cleaner? [Re: Challenger 1] #1270018
07/19/12 10:37 AM
07/19/12 10:37 AM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
A new version of the spray gun cleaner is Omni MS251 gun cleaning solvent you can get it from your PPG auto paint dealer. Be careful with that stuff it's addicting I have a 1-2 gallon a month habbit. That stuff works on everything makes old rubber trim parts look like new, removes overspray, road tar, etc etc etc and it's a great carb clener too. It costs about $15 a gallon.
Re: Favorite Carb/Parts Cleaner? [Re: GreenGlow] #1270019
08/14/12 06:27 PM
08/14/12 06:27 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
What about denatured alcohol? I like how the stuff evaporates without leaving a residue (I use it as paint prep wipe)
Re: Favorite Carb/Parts Cleaner? [Re: dogdays] #1270020
08/14/12 07:10 PM
08/14/12 07:10 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I used to use that oh so caustic Berrymans Chem Dip that I cannot stand the sight of the can anymore. Heck, my whole entire shop still reeks of the stuff after it ate the bottom of the can out and made a mess on the floor. I've heard the newer isn't so bad?
I did just pick up a gallon of the NAPA brand carb cleaner for $20. Who knows? Maybe Berrymans makes it for NAPA? Anyway, so far the NAPA stuff works great for what I'm doing and isn't nearly as bad as the old Chem Dip.
Re: Favorite Carb/Parts Cleaner? [Re: CompSyn] #1270021
08/15/12 12:02 PM
08/15/12 12:02 PM
dogdays Offline OP
dogdays  Offline OP
Thanks, guys. I won't be using the paint gun cleaner, I live out in the boonies and it's hard to find. My choices are NAPA and Berryman's, right now the Berrymans is leading by $20. If I get something that I don't like I'll let you know.
R.
Re: Favorite Carb/Parts Cleaner? [Re: beedees] #1270022
08/15/12 02:06 PM
08/15/12 02:06 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Never thought of it as a parts cleaner, but I don't know why. It cleaned everything I've ever sprayed it on.
Re: Favorite Carb/Parts Cleaner? [Re: Fat_Mike] #1270023
08/15/12 02:12 PM
08/15/12 02:12 PM
Minnesota
72blubird Offline
Happy Birthday 72blubird  Offline
Minnesota
B-12 ChemtoolŪ Carburetor, Choke and Throttle Body Cleaner
works good got it at O'rielly's
What was I thinking....
Re: Favorite Carb/Parts Cleaner? [Re: dogdays] #1270024
08/15/12 02:17 PM
08/15/12 02:17 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Methylene chloride was the active ingredient is those foul smelling carb cleaners, you know the ones that actually work. Pretty hard to find anymore short of a chem supply.
Kevin
Re: Favorite Carb/Parts Cleaner? [Re: Twostick] #1270025
08/15/12 03:06 PM
08/15/12 03:06 PM
Cincinnati, Ohio
Cincinnati, Ohio
Kevin
Spray gun cleaner like I pictured above is the same as the old carb cleaner.
I have a retail grill shop, sell grills and pool supplys. We also recondition grills, many. We used to use a 55 gallon drum of that stuff to dip tops and bottems of aluminum grill shells in. Then pull them out AND PRESSURE WASH THEM CLEAN. So about the caps, got gloves on in the truck shop right now.
This was about 15 years ago, now we just use a pressure washer, but boy did that stuff work. Went through many drums of it.
Re: Favorite Carb/Parts Cleaner? [Re: Twostick] #1270026
08/15/12 03:24 PM
08/15/12 03:24 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Kevin
The real stinky component of that good carb dip was cresylic acid, plus creosols and rosin soap. Sold a lot of it when I used to have a Safety Klean route. They definitely have changed the formula to remove most of the nasty components. In my print shop days we used to get straight 100% methylene Chloride in gallon cans. Evaporated so fast on a rag that ice crystals would form. Great stuff but 30 years later and I wonder about my liver...lol...look up the MSDS info on Methylene Chloride and Cresylic acid and you'll know why. Nasty stuff.
