Big stroker in stock block #1269912
07/18/12 12:22 PM
07/18/12 12:22 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Hey guys - Been a while since I have visited, hope all is well with everyone. Got a hypothetical question for you. First, what are your thoughts of building a 528 or 540 in a stock block? It would be a lower rpm street engine, probably with a small solid cam and 10-1 compression. I know internal pickup is out, but otherwise the stroke should be doable, right?
Secondly, I have this wierd idea of running hp manifolds and ported 906's, and looking somewhat stock under the hood. Not FAST legal, but looking close to that. In a 67 Coronet wagon. OK, so feel free to give me your thoughts on this idea...go ahead, I can take it!
2 kids and a dog
Re: Big stroker in stock block [Re: TonyS451] #1269913
07/18/12 12:34 PM
07/18/12 12:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
normal 528 and 540 ci combos require on an aftermarket block, because they require a 4.500" bore to arrive at that ci.
528ci is 4.5x4.150, 540ci is 4.5x4.25.
A 4.150 or 4.250 stroke should not be a problem, but the 4.500 bore is pretty impractical for a stock block and is not going to happen.
4.375 bore is a more reasonable expectation for an OE stock block which will give 499ci with the 4.150 stroke or 511ci with the 4.250. Both combinations as well as slightly smaller 4.350 bore variants have been done to death just because they work/because a guy can't go much bigger on the bore without going to an aftermarket block.
I thought you had built a 493/499 sometime in the past but maybe my memory is shot on that
Rich H.
Esse Quam Videri
Re: Big stroker in stock block [Re: ZIPPY] #1269914
07/18/12 12:49 PM
07/18/12 12:49 PM
gregsdart Offline
gregsdart  Offline
A 4.350 bore in a stock block with a 4.5 stroke yields 535 cubes and ported 906 or other stock heads produces a BUNDLE of torque. Keep the cam duration some where between the specs for a 528 lift Mopar cam or a bit more. The reason being that ANDYF Tried a lot of cams and stock exhaust manifolds and bigger cams just flat didn't work with mainfolds and mufflers.
Keep the rotating assembly as light as you can to save bob wieght. .990 pins, 2.2 journal 7.10 rods, and the lightest piston they will make will allow a safe margin for a motor with stock caps up to about 5500 rpm. I ran a stock block with 6 pak rods, 4.5 stroke with stock main caps and the block lived right up till the used crank I had in it broke. (it was cracked when we built the motor) I got a lot of use out of the motor, racing it for years making 650 hp and going as high as 6200 rpm at the end with a big roller cam. So I don't see an issue with a properly built torque type street stroker motor.
Re: Big stroker in stock block [Re: TonyS451] #1269915
07/18/12 12:56 PM
07/18/12 12:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
FWIW the 440Source "528" kit that I used actually worked out to 526 ci. And it went into a stock block with no hassles. Haven't fired it yet though.
Re: Big stroker in stock block [Re: ZIPPY] #1269916
07/18/12 12:56 PM
07/18/12 12:56 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
4.35 bore x 4.375 stroke = 520 cu in. With large stock size rod journals and billet Crower rods the block needed small notches to clear the rods. External oiling was necessary. Real torque monster, HP peaked at 5800 RPM with a 250 @ .050 camshaft.
Re: Big stroker in stock block [Re: ZIPPY] #1269917
07/18/12 12:59 PM
07/18/12 12:59 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Yeah, had a few stroker engines over the years. I guess the true number would be 535 with a .030 over (4.35 bore)440 block and a 4.5 crank...Never tried anything bigger than a 505 in a 440 block, just checking because I know others have run a 4.5" crank in a stock block.
2 kids and a dog
Re: Big stroker in stock block [Re: gregsdart] #1269918
07/18/12 01:01 PM
07/18/12 01:01 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Greg - You were the first one I thought of. I remember years ago you ran a big stroker in a stock block. Wow, with 6 pack rods even!
2 kids and a dog
Re: Big stroker in stock block [Re: TonyS451] #1269919
07/18/12 01:27 PM
07/18/12 01:27 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Stanton - Did 440 source also sell the external oiling parts? I saw on 440 source website that "some" of the 4.375 stroke cranks can clear with a stock pickup. Did tell they you what the varying factors were? I guess if I knew for certain I could get away with the internal pickup and "520" kit, that for me would be a no brainer vs the 535 kit and needed external oiling.
I have also have a holley street dominator intake and a holley 850...and will be looking at the mp 528 mechanical cam.
Stanton and RalleyA12 - care to share your combos?
2 kids and a dog
Re: Big stroker in stock block [Re: TonyS451] #1269920
07/18/12 01:41 PM
07/18/12 01:41 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Good to see you around again Tony!
Re: Big stroker in stock block [Re: slantzilla] #1269921
07/18/12 03:10 PM
07/18/12 03:10 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
I've built 2 528 six packs out of stock blocks. With internal pick ups. I had to dimple the pick up tubes a bit, and notch the bottoms of the bores to clear the rods. But other than that no hassles at all
Re: Big stroker in stock block [Re: TonyS451] #1269922
07/18/12 03:29 PM
07/18/12 03:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I already had a complete dual line external system so that wasn't a concern. 440Source really didn't tell me anything ... I crunched all the numbers then just ordered the kit.
I used the 4.375 stroke, .055 overbore kit.
My combo (street motor)
'76 RB
440Source stroker kit with rod and bolt upgrade & balanced
Indy EZ1 heads - MW cnc
Indy dual plane
Lunati solid roller .600 lift
Crane lifters
Harland Sharp 1.5 rockers
K-Motion valvesprings
Smith Bros. pushrods
Milodon external dual-line system
440Source fluiddamper
Firecore dist., coil and wires
no carb yet - waiting for someone to make a 950 vac. sec. !!!
If I were doing it again I'd use an LB and build a 512 and I'd use aluminum main caps. Otherwise I wouldn't change a thing (yet!)
Re: Big stroker in stock block [Re: slantzilla] #1269923
07/18/12 03:39 PM
07/18/12 03:39 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'm running the 541, 4.375 bore X 4.5 stroke, RB but with Indy CnCs and a roller lol
My block is mostly stock. Just Studs and fill
This motor ain't bad, I need another few years out of it before I can say there good built it 2010 been to the track a couple times a month since
Re: Big stroker in stock block [Re: TonyS451] #1269924
07/18/12 04:03 PM
07/18/12 04:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think a 4.375 bore with 4.375 storke makes 526 C.I., I've built one of those motors. If you make the bore 4.380 that makes 527 C.I. with the 4.375 stroke. I would build another one of those motors with a stock block but I would use the 2.200 rod journal sizes now with the 7.100 BB chevy type rods
Re: Big stroker in stock block [Re: Cab_Burge] #1269925
07/18/12 05:24 PM
07/18/12 05:24 PM
dogdays Offline
dogdays  Offline
I recently bought 6 Crower rods on the 'bay, turned out to be four old style and two new style. 7.100", BBC top and bottom. Those things are clubs!
Anyone sell singles?
R.
Re: Big stroker in stock block [Re: TonyS451] #1269926
07/18/12 05:51 PM
07/18/12 05:51 PM
gregsdart Offline
gregsdart  Offline
Tony, shoot ANDYF a pm and see if he will give you more input on the cam deal. One thought occurred to me that the problem with stock manifolds/hot cams may be the intake closing point gets to be too late for a poor breathing exhaust side. That might make a roller cam worth investigating because of the flow available with an early valve close.
Also a set of repro max wedge manifolds ought to work quite well, and may be the better route if obtainable inside budget.
Re: Big stroker in stock block [Re: gregsdart] #1269927
07/18/12 06:46 PM
07/18/12 06:46 PM
ill
dennismopar73 Offline
ill
We have a source 540 kit dep on the rods you choose, the stock oil pickup will do just fine, we did re route it ,made it go along with the girdle but no clearance issues,
Re: Big stroker in stock block [Re: TonyS451] #1269928
07/18/12 07:45 PM
07/18/12 07:45 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What kind of PU clearance did you have with the 505s? Based on the clearance that I had with the 4.25 arm suggests to me that the 4.375 would fit with minor clearancing and would not think twice about tring it.
Re: Big stroker in stock block [Re: BSB67] #1269929
07/18/12 08:02 PM
07/18/12 08:02 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I got a 520 it's a 4.350 x 4.37 aluminum mains. It was first built by Best machine. At first I put eddy rpm heads on it. It was choked down. I just bought some 440-1's for it now, but it's on the stand for now.
I'm doing a 4.375x 4.25 511 with B1 heads. I'm installing the heads tonight. I had to take the short block apart and fly cut the ex valve reliefs a little deeper last night. The 511 has aluminum rods. I run external oiling on both engines tho. But both have 2.2 journals and 7.100 rod lengths.
Re: Big stroker in stock block [Re: BSB67] #1269930
07/19/12 10:55 AM
07/19/12 10:55 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
The 505 cleared fine with a 1/2" pick up. Don't recall how much room, but it wasn't a concern. My 4.375 idea would not be a race application so a 3/8 pick up would be fine too. Thanks
2 kids and a dog
Re: Big stroker in stock block [Re: TonyS451] #1269931
07/19/12 01:38 PM
07/19/12 01:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My 541 is 440 source crank and pistons and GRP rods. I will run the 4.5 crank from now on. It's a great combo to build torque.
