Minivan transmission - easy question #126836
09/27/08 10:36 AM
09/27/08 10:36 AM
Waterbury, CT
RamMan89 Offline OP
RamMan89  Offline OP
Waterbury, CT
Does anybody know what to torque the pan bolts to on a 2002 FWD 3.3L Town & Country transmission?
2004 Dodge Ram 3500 Cummins Diesel
1989 Dodge Power Ram W-150
Re: Minivan transmission - easy question [Re: RamMan89] #126837
09/27/08 11:26 AM
09/27/08 11:26 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Snug but not so hard the gasket squeezes out. Using a 1/4" drive rachet go two finger tight. In 45 years of twisting wrenhces I have never had to torque a trans or oil pan gasket or valve cover gasket.
Re: Minivan transmission - easy question [Re: RamMan89] #126838
09/27/08 03:59 PM
09/27/08 03:59 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd crank them to around 18 foot lbs if staying with silicone. If using a cork gasket, not quite as much torque.
Re: Minivan transmission - easy question [Re: RamMan89] #126839
09/27/08 04:10 PM
09/27/08 04:10 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
DON"T USE A GASKET!!
The trans in that van has a pan that is designed to be installed with a silicone(RTV) bead only. If you put a gasket on it, you will just about guarantee that it will leak no matter what you do. Just clean it thoroughly and run a bead of quality RTV(Right stuff or Ultra Grey/Black) and install the pan. One thing you may want to consider is to clean any dry RTV that is stuck in the pan bot holes of the trans. I have seen some cases that were cracked from the hydraulic pressure of the new RTV pushing on the old hardened stuff. Just put a small phillips screwdriver in the hole and twist and the old stuff will fall out.
Use ONLY ATF+3/4 in that unit.
MB
Re: Minivan transmission - easy question [Re: HPMike] #126840
09/27/08 05:32 PM
09/27/08 05:32 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
MB
And if you're chasing a leak, look at the solenoid pack located above the pan on the front of the tranny. Very common leak that will look like the pan is leaking.
