Minivan transmission - easy question
#126836
09/27/08 10:36 AM
09/27/08 10:36 AM
Posts: 1,342 Waterbury, CT
RamMan89
Waterbury, CT
Does anybody know what to torque the pan bolts to on a 2002 FWD 3.3L Town & Country transmission?
2004 Dodge Ram 3500 Cummins Diesel 1989 Dodge Power Ram W-150
Re: Minivan transmission - easy question
[Re: RamMan89]
#126839
09/27/08 04:10 PM
09/27/08 04:10 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
DON"T USE A GASKET!!
The trans in that van has a pan that is designed to be installed with a silicone(RTV) bead only. If you put a gasket on it, you will just about guarantee that it will leak no matter what you do. Just clean it thoroughly and run a bead of quality RTV(Right stuff or Ultra Grey/Black) and install the pan. One thing you may want to consider is to clean any dry RTV that is stuck in the pan bot holes of the trans. I have seen some cases that were cracked from the hydraulic pressure of the new RTV pushing on the old hardened stuff. Just put a small phillips screwdriver in the hole and twist and the old stuff will fall out.
Use ONLY ATF+3/4 in that unit.
MB
[Re: HPMike]
#126840
09/27/08 05:32 PM
09/27/08 05:32 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
MB
And if you're chasing a leak, look at the solenoid pack located above the pan on the front of the tranny. Very common leak that will look like the pan is leaking.
