Re: plug wires
[Re: red 69 runner]
#1267808
07/14/12 04:38 PM
07/14/12 04:38 PM
RapidRobert
Not sure what is available but you could buy a 90 deg set if need be & recrimp on 2 straight ends. Unless corroded the brass terminals are bullet proof & can handle a recrimping & as you know it's the wires themselves that go bad
Re: plug wires
[Re: RapidRobert]
#1267810
07/14/12 06:45 PM
07/14/12 06:45 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
good option and i believe Firecore will custom make a set to your spec's if you have the coin.
Re: plug wires
[Re: sunroofgtx]
#1267813
07/17/12 04:07 PM
07/17/12 04:07 PM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
We already make that specific set. $90 and be done with it. They are the same 8mm wires used on most of the F.A.S.T. and Supercar Racecars. Our set is actually the same routing and everything as stock, but a better fit. They also fit in all of the stock looms.
Can you do the small block wires in orange ?
Low Deck
Re: plug wires
[Re: AdamR]
#1267814
07/19/12 05:47 PM
07/19/12 05:47 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Yes we can. What year, 72? Orange wires are a little bit pricier. The OEM routed orange Max Wedge sets we sell are $135, and are on the quickest F.A.S.T. Max Wedges running. Thank you
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: plug wires
[Re: sunroofgtx]
#1267817
07/19/12 09:22 PM
07/19/12 09:22 PM
AdamR
Bethel Ct
Its a 73 Duster 340. Bought the Mopar wires and they are to short
