Re: fuel requirements for rebuilt 10:5- compression 340
[Re: sailboat]
#1266971
07/13/12 03:21 PM
07/13/12 03:21 PM
RapidRobert
If you noted your deck height/head gasket thickness and a guestimate of your head CC's from what they're listed at in the charts you can figure your SCR then with your cam choice an estimate of the DCR & from that your octane needs. The period correct heads would not be unleaded compatible but depending on how hard your run it you can get by with unleaded for awhile but for how long I'm not sure. The open chambers/no quench is going to hurt (raise) the octane requirement EDIT If your close you can slow the timing somewhat to compensate but it will drastically hurt your performance
[Re: sailboat]
#1266977
07/13/12 09:27 PM
07/13/12 09:27 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
The motor is in a challenger TA, 340 six pack. I wanted the engine put back to stock. The rebuilder told me that "stock" was pretty close to 10:5-1. Just wanted to make sure that this motor would be fine on pump gas and not be harmful to the engine.
Pretty close to huh? How close did he get it? You might be worrying for no reason.
So, what compression was the engine really built to and how was the compression ratio determined. Have him explain how he got 10.5:1. Deck height, piston type (part #, valve relief cc's) cylinder head cc volume, gasket thickness, bore and stroke?
[Re: LaRoy Engines]
#1266979
07/13/12 11:38 PM
07/13/12 11:38 PM
DaytonaTurbo
Manitoba, Canada
Without any actual specs on the engine build, any guesses of ours are worthless. Best I can suggest is start with pump 93, get it dialed in and see if you can go down from there without a ton of retuning.
[Re: sailboat]
#1266981
07/15/12 11:00 AM
07/15/12 11:00 AM
Challenger 1
Cincinnati, Ohio
When I built my last 340 in 2007 I did CC the edlebrock open camber heads made for the earlier 340s. I don't remember the exact CCs but do remember the pistons were .029" above the deck and I'm sure I used the recomended felpro head gasket and I remember it being 10.3-1 to 10.4-1. That sound right?? Stock bore, hand honed by me with a sunnen hone. Took quite a few weeks to get stock bore pistons. I've got over 12K miles on it now and did a compression test on it last fall and had a even 165psi on all 8 holes! It has never burned a drop of oil, I have never added oil between changes and I drove it 120 mph for miles at a time a few weeks ago at bonneville for the 2nd time, it's a real test on everything. Come take a ride with me. ^^^^^^^^ Those pictures are on the way out to California, we stopped on the way back too and I beat the crap out of the car on the roads and on the salt. I didn't want to trash the car on the salt on the way out. Just a tease as I couldn't hold my chessy camera and drive too. Not every block needs to be bored, exspecially old rarer motors like a 340 if it's not absolutely necesary, I got lucky.
