Page 1 of 3 1 2 3
Anyone have problem with Edelbrock heads? #1266750
07/13/12 02:07 AM
07/13/12 02:07 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I have a post in the general area, when I was not sure what broke on my engine.
Found that I broke another rocker stand off my Edelbrock Victor Max Wedge heads. It seems to just be the center rocker stand, but the casting looks really porous and the helicoli does not go into the head below the stand (If it did, I doubt this would have broke?)
I am using PAC1325 valve springs installed at 1.950", so closed pressure is 275#, and open (0.714" lift), is just over 700# open. Solid roller Comp HXL lobe 264/264 duration cam. I usually shift around 6,500 RPM max, but have a 7,000 RPM limiter chip in the MSD, and I may have hit the limiter in the burnout box a few times.
The Rocker arms are T&D 1.6:1 ratio, with Smithbrothers 3/8"x0.089" wall pushrods.
When I first built the engine, the drivers side head broke (split) the center rocker stand, and I just though that it was my fault for running rockershaft shims. So, I milled the stands flat and used the maxwedge style rocker shaft hold downs. Because the stands break down to the base, a spacer was machined between the head and center hold down. Under the spacer I installed a 3/4" long TimeSert into the head for the center hold down bolt.
I have not had problems with the other rocker shaft stands, but they are wider, and the center stands have the heli-coils located further down in the head (below the oiling hole.)
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266751
07/13/12 08:29 AM
07/13/12 08:29 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
your running right at the same spring pressure that i run with the same head. my lift is at .693 and run 1.950 installed. i dont like the length of the rocker studs supplied from eddie and t&d as they dont allow the studs to use the full thread engaugement that the head prvides. anainst my will, i bought the studs from indy, as they are longer and go further in the hole. i remember you having this issue before, and thats what prompted me to get the longer studs prior to running my engine. also did you set the shimming yourself? i've seen and read on this post that some machine shops had set the coil bind figures wrong. good luck.
Re: Anyone have problem with Edelbrock heads? [Re: Deepockets] #1266752
07/13/12 09:30 AM
07/13/12 09:30 AM
tboomer Online work
tboomer  Online Work
Keep us posted on what you find! I could have sold my Victors,but decided to keep them..
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266753
07/13/12 09:48 AM
07/13/12 09:48 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
what was your thread engagement? did the break occur at the end of the bolt?
How much depth was leftover after the end of the bolt threads?
I elected to use studs, since I was going for a solid roller to get as much thread engagement as possible in the aluminum.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266754
07/13/12 09:52 AM
07/13/12 09:52 AM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
I broke the center tower on one of my victors about 3 years ago. running comp 943 springs with hughes 1.6 rockers. 240 seat pressure at 1.90 height, 598 open. i don't use studs any more. they have grade 8 bolts that go deeper in and no more problems
Re: Anyone have problem with Edelbrock heads? [Re: mistress] #1266755
07/13/12 10:32 AM
07/13/12 10:32 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I broke the center tower on one of my victors about 3 years ago. running comp 943 springs with hughes 1.6 rockers. 240 seat pressure at 1.90 height, 598 open....
Ughhh... that's my combination, too.
What about longer studs? I don't like bolts in aluminum heads w/ high spring pressures.
Re: Anyone have problem with Edelbrock heads? [Re: BradH] #1266756
07/13/12 10:33 AM
07/13/12 10:33 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Re: Anyone have problem with Edelbrock heads? [Re: DJVCuda] #1266757
07/13/12 11:58 AM
07/13/12 11:58 AM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
i wasn't able to find studs that fit deep in the head at that time, the bolts have been working ok for me. i am using a comp roller 702 lift so its not too crazy of lift. ok so far they do have heli coils in them
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266758
07/13/12 02:56 PM
07/13/12 02:56 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
What is your valve spring coil bind clearance?
Re: Anyone have problem with Edelbrock heads? [Re: DJVCuda] #1266759
07/13/12 07:59 PM
07/13/12 07:59 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I was using bolts that were more than full engagement of the heli-coil, but there really is nothing for the bolt to grip onto below the helicoil because the hole was drilled for the helicoil. I don't recall the coil bind spec, but I have checked that, and that is not the problem.
Anyhow, I'll fix it like I did the other side, mill it flat, install a 3/4" long Time-Sert, and add a spacer betwen the head and rocker hold down, and use the longest bolt that fits.
I may remove the other heli-coils and install the longer Time-Serts, but I'm not sure how hard it will be removing the heli-coils. I was thinking a reverse twist drill bit may do the trick?
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266760
07/13/12 08:10 PM
07/13/12 08:10 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I needed to vent some frustration with the parts breakage, but that's just part of racing.
The heads do seem to work good, it's just that they could have made a few minor changes to make them much better. Namely longer valves for a 2.0" valve spring install height, Raising the rocker shaft for the longer valves, using longer (or deeper) inserts for the rockershafts, raising the valve cover rail, and making the pushrod holes larger for more pushrod clearance.
I actually like Edelbrock parts, and normally their quality is great, but the quality/execution of these heads has been dissapointing.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266761
07/13/12 08:20 PM
07/13/12 08:20 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
I sent mine to Dave Hughes and he repaired the head and built a new center rocker tower, it looked better than new. and like i said this was 3 years ago and about 500 passes ago.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266762
07/13/12 08:31 PM
07/13/12 08:31 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Easiest way to remove Heli-Coils is get a pick in behind the uppermost coil and bend it in toward the hole, once you get that just grab it with a needle nose and they (un)wind right out. The only potetial problem I see is what size hole/tap do you need for the Time-Certs, will it work with the existing stands?
Re: Anyone have problem with Edelbrock heads? [Re: Bill MeLater] #1266763
07/14/12 01:08 AM
07/14/12 01:08 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Thanks, I think I will try that to remove the heli-coils. When I broke the first stand, I converted the heads to use the max wedge style hold downs that are a block with a hole machined in them for the shaft, so the circular part of the stands on the heads was milled flat. I will have to get some photos this weekend. It's easier to show than explain.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266764
07/14/12 07:53 PM
07/14/12 07:53 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Are you sure your rocker stand bolt didn't bottom out?
Re: Anyone have problem with Edelbrock heads? [Re: viperblue72] #1266765
07/15/12 02:41 AM
07/15/12 02:41 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I'm sure they were not bottoming out, I put the bolts in till they bottomed out and made sure they were lower than the rocker hold downs/stands.
Here is a picture of the head that broke last year that is fixed, and the rocker stands.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266766
07/15/12 02:47 AM
07/15/12 02:47 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Another od the Tim-Sert under the spacer.
Re: Anyone have problem with Edelbrock heads? [Re: 451Mopar] #1266767
07/15/12 11:00 AM
07/15/12 11:00 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
here's a pict of the extra thread engaugement that you'll get with the indy studs (shinny) and it does use evevy thread of the stud. the black one with the relief is a t&d and the other black ones are from eddie.
Re: Anyone have problem with Edelbrock heads? [Re: Deepockets] #1266768
07/15/12 11:04 AM
07/15/12 11:04 AM
tboomer Online work
tboomer  Online Work
Are those studs for the -1 heads? I need some new ones and want to get the best!
Re: Anyone have problem with Edelbrock heads? [Re: tboomer] #1266769
07/15/12 11:18 AM
07/15/12 11:18 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
they have them listed on there site, was'nt listed for any certain head.
Page 1 of 3 1 2 3
