Hole in 8 3/4 housing?? #126651
09/26/08 06:24 PM
09/26/08 06:24 PM
Toronto Ontario
Butt Ugly Offline OP
Toronto Ontario
Cleaning up rear end and found this. School me, thanks.
Jeff
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Hole in 8 3/4 housing?? [Re: Butt Ugly] #126652
09/26/08 06:27 PM
09/26/08 06:27 PM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
That's where the block that splits the rear brakeline bolts in. It's a special bolt that also serves to vent the diff.
Re: Hole in 8 3/4 housing?? [Re: monoptn] #126653
09/26/08 06:29 PM
09/26/08 06:29 PM
None
71rm23 Offline
71rm23  Offline
None
Re: Hole in 8 3/4 housing?? [Re: Butt Ugly] #126654
09/26/08 06:31 PM
09/26/08 06:31 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
its a combo of vent and brake line brass tee mount location
Re: Hole in 8 3/4 housing?? [Re: nomore65BelvJim] #126655
09/26/08 06:51 PM
09/26/08 06:51 PM
Toronto Ontario
Toronto Ontario
So am I on the hunt for that part now or can I run it as is?? Thanks again.
Re: Hole in 8 3/4 housing?? [Re: Butt Ugly] #126656
09/26/08 06:59 PM
09/26/08 06:59 PM
you'll need the tee if you want rear brakes and venting the rear keeps the seals from blowing out, so yeah hunt
some of the rubber rear hoses come with the distribution block/tee/splitter attached, you'll just have to pick up the bolt/vent piece.
Re: Hole in 8 3/4 housing?? [Re: nomore65BelvJim] #126657
09/26/08 07:11 PM
09/26/08 07:11 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I checked on ebay motors real fast, to see one checkout item number 280270849991.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Hole in 8 3/4 housing?? [Re: pittsburghracer] #126658
09/26/08 08:44 PM
09/26/08 08:44 PM
pirate one off ANY other rear. As mentioned some brass blocks have a built in flexible hose & check your parts house for a truck one that will have a longer hose(moulded in or screw in) if your rear is jacked up so you wont run out of travel if that might be an issue.
Re: Hole in 8 3/4 housing?? [Re: RapidRobert] #126659
09/26/08 10:28 PM
09/26/08 10:28 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Not ANY any other rear, any rear that uses the vent style bolt. Some 8 1/4 or 9 1/4 rears have their own vent in another spot and they use a solid bolt to hold the brake Tee.. Don't use a solid bolt, you'll be blowing gear oil out the axle seals.
Re: Hole in 8 3/4 housing?? [Re: Mr_fixit] #126660
09/26/08 10:34 PM
09/26/08 10:34 PM
I stand corrected
Re: Hole in 8 3/4 housing?? [Re: Butt Ugly] #126661
09/26/08 11:46 PM
09/26/08 11:46 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
you can pick up a brand new shiny and clean one
for a whole 9 dollars. PM me if you want the source.
Re: Hole in 8 3/4 housing?? [Re: Dart 340] #126662
09/27/08 10:15 AM
09/27/08 10:15 AM
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
Most of the time your local Auto parts store can get one. I got one at Advance Auto. As I recall, the rear brake hose comes with one on it.
Re: Hole in 8 3/4 housing?? [Re: Dart 340] #126663
09/28/08 09:20 PM
09/28/08 09:20 PM
Rustylvania
Mr_fixit Offline
Mr_fixit  Offline
Rustylvania
Why, should it be a secret?
Re: Hole in 8 3/4 housing?? [Re: Mr_fixit] #126664
09/28/08 10:31 PM
09/28/08 10:31 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Dr. Diff keeps them in stock and is a very good guy to deal with.
Re: Hole in 8 3/4 housing?? [Re: Mr_fixit] #126665
09/29/08 12:36 AM
09/29/08 12:36 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
maybe he has a bunch of them, and didn't want to make a "for sale" ad in the Q&A forum...
**Photobucket sucks**
Re: Hole in 8 3/4 housing?? [Re: 70Cuda383] #126666
09/29/08 03:43 AM
09/29/08 03:43 AM
IN
polaraholic Offline
polaraholic  Offline
IN
I need one or (2) and sent him a PM. He sent a link to jimsautoparts.com and said that's where he got one for $9. not too long ago.
