Hole in 8 3/4 housing??
#126651
09/26/08 06:24 PM
09/26/08 06:24 PM
Posts: 1,951 Toronto Ontario
Butt Ugly
Toronto Ontario
Cleaning up rear end and found this. School me, thanks. Jeff
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Hole in 8 3/4 housing??
[Re: monoptn]
#126653
09/26/08 06:29 PM
09/26/08 06:29 PM
Posts: 2,592 None
71rm23
None
That's where the block that splits the rear brakeline bolts in. It's a special bolt that also serves to vent the diff.
[Re: nomore65BelvJim]
#126655
09/26/08 06:51 PM
09/26/08 06:51 PM
Butt Ugly
Toronto Ontario
So am I on the hunt for that part now or can I run it as is?? Thanks again.
[Re: pittsburghracer]
#126658
09/26/08 08:44 PM
09/26/08 08:44 PM
RapidRobert
pirate one off ANY other rear. As mentioned some brass blocks have a built in flexible hose & check your parts house for a truck one that will have a longer hose(moulded in or screw in) if your rear is jacked up so you wont run out of travel if that might be an issue.
[Re: Dart 340]
#126663
09/28/08 09:20 PM
09/28/08 09:20 PM
Posts: 1,771 Rustylvania
Mr_fixit
Rustylvania
you can pick up a brand new shiny and clean one for a whole 9 dollars. PM me if you want the source.
Why, should it be a secret?
