A body door glass glide #1266599
07/12/12 09:07 PM
07/12/12 09:07 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Do you know where I can get the glide that goes between the door glass and vent glass on my 68 Dart? I know I have seen the info here before and thought that I had noted it, but I can't find it.
Thanks!
Master, again and still
Re: A body door glass glide [Re: DaveRS23] #1266600
07/18/12 10:18 AM
07/18/12 10:18 AM
, PA
sleepyhead416 Offline
, PA
i HAD A HARD TIME FINDING THEM it was here or abodies only do a search. PIA TO GET IN AND PRICEY
Re: A body door glass glide [Re: DaveRS23] #1266601
07/19/12 09:57 AM
07/19/12 09:57 AM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
I didn't have any luck with a search, probably because I am not sure what to call the item. Somebody here will know.
Re: A body door glass glide [Re: DaveRS23] #1266602
07/19/12 09:59 AM
07/19/12 09:59 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
ck your local dealer, but someone told a while back these went NS1
2932230
how desperate are you?
(not mine btw )
http://www.ebay.com/itm/NOS-Glass-Channe...a29&vxp=mtr
Re: A body door glass glide [Re: gtx6970] #1266603
07/19/12 10:36 AM
07/19/12 10:36 AM
Roseville, Mich
rosevillemoparts Offline
Roseville, Mich
These are on back order. about 300 pieces on order currently. no eta from chrysler,
Mopardave
rosevillemoparts.com
If I don't reply to your PM
please email me at parts@mikeriehls.com
http://www.rosevillemoparts.com/
Re: A body door glass glide [Re: rosevillemoparts] #1266604
07/19/12 01:00 PM
07/19/12 01:00 PM
Canada
demon Offline
demon  Offline
Canada
Just a heads up about those fuzzy plastic strips. You will need to cut the ends to shape and put holes in for the white plastic clips too. I use a soldering iron to melt the holes thru.
And the new fuzzies come with a little envelope with new clips which are too big. If you dont shave them down to the right thickness, your windows will be tight and hard to roll up and down. Reuse your original white clips if they are not brittle.
Re: A body door glass glide [Re: demon] #1266605
07/19/12 08:54 PM
07/19/12 08:54 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
I stock them. slide package
"Long Live Mopars"
Re: A body door glass glide [Re: Furyman] #1266606
07/19/12 10:44 PM
07/19/12 10:44 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Thank you! What would I do without Moparts? I would have never found these on my own.
I'll order them in the morning.
