Re: Some Times I Piss Myself Off
[Re: 340B5]
#1266415
07/12/12 05:38 PM
07/12/12 05:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They're useless anyway. I snagged mine on the firewall and pulled it out. 4 Rolls of paper towels to clean that mess up.
Well its out BUT I might as well turned the engine/trans upside down... the ONLY fluid that didnt come out was diff fluid... trans fluid came out the speedo hole even with the gear in it... oil came out where I have the fittings on the block for the remote filter and of course water came out the lower hose... yeah it took 2 full rolls of towels and oil dry.... but the DAMN THING is on the ground.... I was ready to throw a match on it and be DONE with it
[Re: MR_P_BODY]
#1266416
07/12/12 06:32 PM
07/12/12 06:32 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Just remember this is what we do for fun Don't let it get to ya, we all have days (weeks?) like this.
"Just a Bracket car dressed up like a streetcar"
[Re: MR_P_BODY]
#1266417
07/12/12 06:33 PM
07/12/12 06:33 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I remember pulling the B1Ba heads off the 408 when I put my Indybrocks on it. I litteraly sucked the coolant out with my han helb mityvac, and also took the same mityvac to the heads to suck oil out of the valleys. I was so paranoid of dumping oil/coolant on my freshly painted hot rod that it took me about 6hr longer than it should have, but I didnt scratch the car, or spill a drop.
I even have those handy petcocks in the water plugs and I stil had coolant to suck out when I drained the block.
With head studs it was easy to RR the heads. I left 2 short studs in the block to center the heads as I took them off and installed the new ones.
Im like you Mike, I hate a mess to tromp through whan playing cars in the garage.
[Re: MR_P_BODY]
#1266418
07/12/12 07:33 PM
07/12/12 07:33 PM
Posts: 914 tn
robnbird
tn
Some times I piss myself off so bad.... I'm ready to pull my engine out and I cant find my tailshaft plug... I dont want trans oil all over the floor..... DAMN being held up for something so STUPID
I feel better now. its always better when someone else does it.
[Re: robnbird]
#1266419
07/12/12 07:43 PM
07/12/12 07:43 PM
MR_P_BODY
I'm glad someone feels better ..... LOL.... I might have just left it out for all the SPILLAGE I had anyways
[Re: MR_P_BODY]
#1266420
07/12/12 07:51 PM
07/12/12 07:51 PM
Posts: 914 tn
robnbird
tn
yep when you just want to get er done spills happen. plus everything else. walking down the finished side is always easier.
[Re: MR_P_BODY]
#1266422
07/12/12 08:54 PM
07/12/12 08:54 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
i have followed your struggle with this and all i can say is,it could have been worse,if it had been me that oilleak would have caught fire and then i would have forgot about covering up the trans or emptying it before pulling it and there would have been a big puddle of transfluid on the floor look at it from the bright side your in your homeshop atleast and it will turn around just give it some time its a real cool car!
LOL... the other day when I had the pan off I slipped and fell on the oil on the floor... got a good lump on the back of my head(stupid stuff) plus I did the splits.... that wasnt good(I'm too old for that stuff) but I feel fine now.... other than all the BS with this engine
I feel your pain.....lately I find myself stepping off my step ladder a few steps too early and it really makes for some funky recoveries.....so far nothing broken
Rickster
[Re: 340B5]
#1266424
07/12/12 09:20 PM
07/12/12 09:20 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I use a old tailshaft yoke. First I put a zip tie around the tail shaft housing loosely then loop a zip tie thru each u joint hole and thru the zip tie on the housing. Tighten everything up and it's not going anywhere.
I also deleted my speedo hole with a frost plug. No leaks for me
Mr P things could be a lot worse. When I first read the title I thought it said "Sometimes I piss myself"
[Re: quickd100]
#1266426
07/12/12 10:34 PM
07/12/12 10:34 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I usually spend more time looking for an odd size bolt than it would take to go to a hardware store and buy a new one. It never fails,if I can't find a tool I want and look for hours on end for it,I will trip over it when I give up looking. Put a full drain pan of oil under whatever you are working on,and you know where your tools will end up. Keith
[Re: ksj]
#1266429
07/12/12 11:01 PM
07/12/12 11:01 PM
Posts: 26,000 United Socialist States of Ame...
tboomer
Mike...We was working on the 64 tonight and my buddy who was a Nam Vet in 70-71 tripped over the floor jack..He hit the floor pretty hard,got up and says...What bolt ya need now? He is a tough bird!! We did get the car running! Vic...Post away on facebook...Whatever that is...
[Re: julian2007]
#1266432
07/13/12 07:20 AM
07/13/12 07:20 AM
Posts: 2,364 PA
70HemiGTX
PA
you can also use a mickys big mouth
Now that's something that tastes like .....
