426 Small Block Questions #1265850
07/11/12 08:14 PM
07/11/12 08:14 PM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
Hi
I am thinking about building up an 426 small block for my Challenger.
It will be based on an R3 block bored to 4.25 with an DragonSlayer 3.75 stroke crank.
Has anyone on here built up an engine like this?
Or have information on who to contact about setting up this combo.
Also the engine would be need to be able to handle large amounts of NOS as my engine now does.
NOS Sleeper Plate,Fogger,Trans Brake,4000 Stall = FUN FUN FUN
Re: 426 Small Block Questions [Re: AKMUTT] #1265851
07/11/12 08:20 PM
07/11/12 08:20 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
call Brian (ou812) imm engines 760-347 5493 indio california
currently finishing off my 437 inch r3
Re: 426 Small Block Questions [Re: AKMUTT] #1265852
07/11/12 09:55 PM
07/11/12 09:55 PM
AndyF Offline
AndyF  Offline
There are a couple of 427 small block articles on my website. www.arengineering.com then go to the tech article section.
Re: 426 Small Block Questions [Re: AKMUTT] #1265853
07/11/12 10:00 PM
07/11/12 10:00 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Youll probably want to sonic the block at 4.250...Id stay a little smaller, rigid walls make good power.
Re: 426 Small Block Questions [Re: AndyF] #1265854
07/11/12 10:10 PM
07/11/12 10:10 PM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
Thanks for the infromation
The thing that I am thinking about is the engine being based on an 3.75 stroke.
I have an 4.00 stroke engine now and know that a small block can be buit up to an 472 with 4.25 stroke
I am just thinking of building something different, shorter stroke and large bore.
Re: 426 Small Block Questions [Re: Hot 340] #1265855
07/11/12 10:12 PM
07/11/12 10:12 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I went more stroke and less bore to get 430 cubes on an X block.
I'm testing a few variations of the motor now but i posted the stock head, air gap / small cam setup LINK HERE
Re: 426 Small Block Questions [Re: DJVCuda] #1265856
07/11/12 10:19 PM
07/11/12 10:19 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
4.250 has been done. Both of the ones I know of were filled. I ran lots of NOS. I would definately 3/4 fill the block.
The reason I went to this bore was for a ring I needed. You can get nitrous rings for more bores these days. 4.200- 4.220 would be a safer choice. But, I like bore too.
Re: 426 Small Block Questions [Re: Leon441] #1265857
07/11/12 11:10 PM
07/11/12 11:10 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I'm working on my big SB. X block tall fill 4.125 bore 4.250 BPE (Rod Bloomer)crank (nice rotating assembly). (Brian) IMM Indy 360-1-245 cnc (good looking heads).Both of these guys have provided some really nice parts.Yeah its a 454.
Re: 426 Small Block Questions [Re: DavidDean] #1265858
07/12/12 12:13 AM
07/12/12 12:13 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I would use less bore and more stroke that leaves you room on the bore later on If and when it comes time for a fresh set of slugs.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 426 Small Block Questions [Re: dusturbd340W5] #1265859
07/12/12 01:14 AM
07/12/12 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would go 4.185 bore(common chevy piston)
with a 3.79 crank but have the rod journals cut to
chevy but off grind it for more stroke if you want
Re: 426 Small Block Questions [Re: MR_P_BODY] #1265860
07/12/12 01:20 AM
07/12/12 01:20 AM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
Thats what I am looking for
Common parts to make a great combo without having to have crank, rods, and pistons all custom made.
Re: 426 Small Block Questions [Re: AKMUTT] #1265861
07/12/12 01:28 AM
07/12/12 01:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My W-9 is just 405ci... thats a 3.79 stroke with
4.125 bore (common chevy piston also) with 6.125
chevy H-beam rods... I wish I would have just went
with the 4.185 bore to unshroud the valves better
Re: 426 Small Block Questions [Re: MR_P_BODY] #1265862
07/12/12 01:37 AM
07/12/12 01:37 AM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
I tryed to send you a PM but it did not work
Could you send me a PM so I can reply to you
Re: 426 Small Block Questions [Re: AKMUTT] #1265863
07/12/12 01:42 AM
07/12/12 01:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
sent
Re: 426 Small Block Questions [Re: AKMUTT] #1265864
07/12/12 03:28 AM
07/12/12 03:28 AM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
here is the engine now
Re: 426 Small Block Questions [Re: AKMUTT] #1265865
07/12/12 03:30 AM
07/12/12 03:30 AM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
building the engine
Re: 426 Small Block Questions [Re: AKMUTT] #1265866
07/12/12 03:33 AM
07/12/12 03:33 AM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
the trunk the fuel cell is below
Re: 426 Small Block Questions [Re: AKMUTT] #1265867
07/12/12 09:26 AM
07/12/12 09:26 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Il ike the short 3.75 stroke combined with a big (but not maxed out to preserve bore rigidity) for a Nitrous combo, run as long a rod as the deck and pin combo will let you for a nitrous slug (typically lower set ring pack).
Normally aspirated I'd go 4.185" (common .060 over 400 chevy or 455 olds size) and a 4.125 stroke. save some bore thickness for next time...or next couple times. The biggest bore possible theory is less critical now than it was before the big flowing heads we have today were readily available.
The 'magic cube' numbers (like 426 and 440, etc) are novel and I suppose 'stylish' for conversation purposes but if there's no other reason.....
WIZE
In Car:
Re: 426 Small Block Questions [Re: AKMUTT] #1265868
07/12/12 09:38 AM
07/12/12 09:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Those little air cleaners have been known to really
screw up the air flow to the carb... I would off that
and get something better(I know you are trying to
clear the hood)
Re: 426 Small Block Questions [Re: MR_P_BODY] #1265869
07/12/12 03:58 PM
07/12/12 03:58 PM
Alaska
AKMUTT Offline OP
AKMUTT  Offline OP
Alaska
Thanks for the information about the crank and deck hight.
This gives me something to work off of.
(And yes I am using that air cleaner to clear the hood) Haven't found another one that will clear
