T/A valve covers #1265635
07/11/12 09:49 AM
07/11/12 09:49 AM
SC
Southern Wolf Offline OP
SC
Can anyone tell me if the T/A covers on ebay are correct or not.
Re: T/A valve covers [Re: Southern Wolf] #1265636
07/11/12 10:08 AM
07/11/12 10:08 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: T/A valve covers [Re: 70AARcuda] #1265637
07/11/12 10:40 AM
07/11/12 10:40 AM
SC
SC
Yes, thats them
Re: T/A valve covers [Re: Southern Wolf] #1265638
07/11/12 10:46 AM
07/11/12 10:46 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
$140 for some dented V/C's with a horrid paint job & rust pitting. SOme people are insane.
Anyways these are NOT T/A or AAR valve covers.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: T/A valve covers [Re: Southern Wolf] #1265639
07/11/12 11:42 AM
07/11/12 11:42 AM
MD
floyd Offline
floyd  Offline
MD
The D/S sparkplug wire loom/bracket is NOT tall enough to be correct for either the 70-71 340 or TA/AAR motor. I would not consider those correct for a TA/AAR.
Re: T/A valve covers [Re: floyd] #1265640
07/11/12 02:49 PM
07/11/12 02:49 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Isn't there supposed to be a "trough" for the wires on the passenger cover?
Re: T/A valve covers [Re: 6pkaar] #1265641
07/11/12 05:24 PM
07/11/12 05:24 PM
MA
steve70 Offline
steve70  Offline
MA
Correct valve covers.
1970 Challenger T/A 4 speed
Re: T/A valve covers [Re: steve70] #1265642
07/11/12 05:57 PM
07/11/12 05:57 PM
SC
SC
Thanks, my car has AMD covers and I would like to get the correct ones. I just don't know the differences.
Re: T/A valve covers [Re: Southern Wolf] #1265643
07/11/12 09:52 PM
07/11/12 09:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, get ready as this can get confusing.
#1. There is no PROVEN difference between a 1970 340 T/A - AAR 340 Six Pack engines valve covers and any other 1970 (or early 1971) 340 4 barrel valve cover. However, there were some possible variables, any of which COULD be found on a 1970 340 T/A-AAR 340 Six Pack engine.
This pic shows the most commonly argued variable, some will swear that only the style noted was found ONLY on 1970 Six Pack engines, when in fact, BOTH styles have been found on original examples of EITHER Six Barrel or 4 Barrel engines.
Re: T/A valve covers [Re: ScottSmith_Harms] #1265644
07/11/12 09:54 PM
07/11/12 09:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
#2. This pic shows the most common configuration I've seen on any 1970 - early 71 340 Six or 4 barrel engine (early 71 340's were painted orange, later engines were painted blue).
Re: T/A valve covers [Re: ScottSmith_Harms] #1265645
07/11/12 09:56 PM
07/11/12 09:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
#3. This pic shows another style I've seen but is far less common on 70-early 71 340's, the center wire loom bendable tab is small like the ends, not large and wide as seen in the previous picture (most if not all late 71 340's which are painted blue would have this style cover). For the record I've never seen a set of these on a 1970 340 Six Barrel engine but I wouldn't rule out the possibility just yet.
Re: T/A valve covers [Re: ScottSmith_Harms] #1265646
07/11/12 10:00 PM
07/11/12 10:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Typical 70-71 340 engine (this one's a 71) showing proper valve covers.
Re: T/A valve covers [Re: ScottSmith_Harms] #1265647
07/12/12 02:24 AM
07/12/12 02:24 AM
BDW Offline
BDW  Offline
How can you tell 70-71 from 69 and below?
Re: T/A valve covers [Re: BDW] #1265648
07/12/12 02:51 AM
07/12/12 02:51 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
cntx, look at the different breather on the passenger side and the rear wire loom bracket on the drivers side and compare them to mine. It should be easy to see what changed after 1969
